Now offering Archive Garage leaf spring and rear suspension products!
Started by Marlin Crawler, April 26, 2025, 02:38:04 PM
Marlin Crawler
Now offering many popular USA-made Archive Garage products!
We've been installing Archive Garage Rear Suspension Products onto customer rigs for a while now and have just added over a dozen new products to our website! And what's more, we've worked out a way to offer all of these for FREE SHIPPING!
If you've got a Tacoma or Tundra, check em out! (Everything is also currently on sale through tomorrow!)
2005-2023 Tacoma Rear Suspension Kit
A package of proven components all designed to work together, from one trusted source, Archive Garage. Whether you're off road trail running or taking on your next overland expedition we...
$2,590.00 – $3,050.00
View product
Archive Garage Explorer Series "ERIKSON" Lift Leaf Springs, for 2005-23 Tacoma
Archive Explorer Series Tacoma leaf packs are designed for severe duty off road travel. Made in USA with 5160 steel, tip insert pads, full military wrap yet won't scrape hanger,...
$950.00 – $1,190.00
View product
Traveler Add-A-Leaf AAL (stock springs) for 2005-23 Tacoma
Adding armor, hauling or towing? Archive Garage's Traveler Leaf is specifically designed to enhance stock 2005-23 Tacoma rear leaf spring packs. The Traveler Leaf: Improves load handling Reduces rear squat...
$175.00
View product
Outboard Shock Relocation (OSR) Kit for 1995-04 Tacoma
This is Archive Garage's Outboard Shock Relocation Kit for 1st gen Tacomas. This kit relocates your rear shocks from inside your leaf springs and frame rails to the outside, in...
$320.00
View product
2.0″ OD Rear Shock Relocation Tower Kit for 2005-23 Tacoma
These awesome "Trail Series" Shock Relocation Towers for 2.0″ OD shocks running 12″ to 14″ of stroke length are a great option for 2nd and 3rd gen Tacoma owners who...
$280.00
View product
2.5″ OD Rear Shock Relocation Tower Kit for 2005-23 Tacoma
Archive Garage introduced the original 2.5″ kit to mount 2.5″ x 12″ to 2.5″ x 14″ travel shocks without cutting your bed nearly a decade ago! This "under bed" kit...
$580.00 – $600.00
View product
Hammer Hangers®, HD Shackle Hangers for 2005-23 Tacoma
The original Hammer Hangers® for 2005-2023 Tacoma make your ride quality noticeably better, improve handling by reducing rear sway and support increased travel capacity (12″ to 14″ travel).  Vastly increase...
$490.00 – $770.00
View product
Cross Tube Option for 2005-23 Tacoma Hammer Hangers®
Now with more beef!  New 2″ diameter square tubing w/ 50,000 psi tensile strength (former design was only 1.75″ diameter) Square tube is better than round for this application because...
$50.00 – $250.00
View product
Lower Axle Shock Tab Mount For Rod End Shocks (pair)
A pair of quality gusseted axle shock tab mounts that put the shock eye center 4″ off axle OD.  As such it can be mounted clocked up, horizontal or clocked...
$90.00
View product
U-Bolt Flip Kit, Archive Garage, for 2005-23 Tacoma, 2000-06 Tundra
This Archive Garage's Stealth Heavy Duty U-Bolt Flip Kit for 2005-2023 Tacoma and 2000-2006 Tundra fits stock 60mm (2.375″) wide leaf springs and up to 2.5″ wide springs. U-Bolts are...
$150.00 – $310.00
View product
Round U-Bolts for 2005-23 Tacoma and 2000-06 Tundra
These are replacement Round U-Bolts for U-Bolt Flip Kits. For replacement Square OE-style U-Bolts, please click here. Features include: Made in USA Clear-zinc (silver) for corrosion resistance Diameter & thread...
$60.00
View product
Square OE-style U-Bolts for 2005-23 Tacoma and 2000-06 Tundra
These are replacement Square OE-style U-Bolts. For replacement U-Bolts for U-Bolt Flip Kits, please click here. Features include: Made in USA Clear-zinc (silver) for corrosion resistance Diameter & thread pitch:...
$60.00
View product
Extended Brake Line Kit, 26″, 2005-23 Tacoma
These Brake Lines are 26″ long which is required when running 14″ travel rear shocks on a rear leaf spring 2005-2023 Tacoma. Since the mid 90's Crown Performance Brake Lines...
$160.00
View product
Archive Garage "Speed Bump" Bump Stops for 2005-23 Tacoma & 2000-06 Tundra with Rear U-Bolt Flip Kit
Archive Garage bump stops for Option 3 and Option 4 u-bolt flip kits. Features of the Archive "Speed Bumps" bumpstops include: Soft Engagement, ,Maximum Bump Travel, Slows compression forces over a greater distance for a more progressive feel...
$150.00
View product
All of the above are now available for online checkout! Free Shipping and 10% OFF? Don't miss out!
View Leaf Spring Upgrades
View Shock Tower Upgrades
The above products complement RCLT HD very well!
Thank you for supporting the off-road community and helping us keep quality & innovation alive since 1994.
- The Marlin Crawler Team
Check out our 10% off 250th Anniversary Sale – LIVE NOW!
Private Messages are not monitored
Please contact us at MarlinCrawler.com/contact or (559) 25-CRAWL / 559-252-7295
