3vze Crank No Start
Started by bweigel25, September 09, 2024, 06:56:37 PM
bweigel25
I have a 94' Toyota Pickup 4wd 5 speed. Truck has 3vze engine with around 375k on the clock. Truck has set for about 3 months and doesn't get daily driven due to having kids. Tried to start truck and no start. Decided to replace fuel pump as not being able to hear run while jumping diag port. Replaced fuel pump and still no run, found broken wire at sender. Have used jumper wire to run fuel pump and truck will still not start. Have tested for spark at distributor cap. Test one injector pigtail that was easy to get to with noid light and have voltage to injectors. Removed jumper wire and tested AFM with hand with key on and am getting operational fuel pump. Removed spark plug on passenger side, different cylinder that I tested with noid light, am getting good blue spark and plug was wet with fuel. Truck will not hit at all. Only time truck will hit is when you let it sit overnight it will hit once and never again. Heads and timing belt were redone 150-175k ago. Before truck had been parked it had developed a rough idle and every once in awhile it would miss and stall but I could allways clutch it rev it up and it would work fine. That issue was getting more frequent. I am kind of stumped at the moment and am looking for some advice.
Thank you
