VSS issues
Started by Ritchie, June 15, 2024, 08:35:58 AM
Ritchie
So I have an issue with the VSS on my Low Range transfer case. For example, If I'm doing 40mph, the speedo hits 40, then bobs back and forth from 30 - 40... I jumped on the Low Range site and ordered a new part.
What I received (Trail Gear) was different than the part I have. So I contacted Low Range, spoke with Dylan, sent him photos, and the replacement part was on it's way.
Problem is, it does not work... is there a trick to this? It installs in 30 seconds.
Wondering if anyone has had issues with this.
Thanks in advance for the replies.
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
blackdiamond
I probably can't help you, but you'll need to provide a little more information about your vehicle for others I would expect.
Ritchie
2003 Tacoma Prerunner.  I have an Inch Worm TC from Low Range, and the VSS is crapping out. I contacted them and they sent me a Trail Gear part, and it does not work at all. A non-functioning VSS throws a PO500 code, so the check engine light came on. I put the old VSS back in and the light is gone. Speedo bounces all over the place.
OVRAROK
Ritchie
