How much longer are 89+ springs?
Started by 86yota, April 17, 2005, 06:43:27 PM
86yota
How much longer are stock rear 89+springs than the springs in my 87?  The reason I'm asking is I need to corect my shackle angle.  My new 9" shackles are nearly verticle and I'd like to be somewhere closer to 45 degrees.
IronClad
they are like a 51 or 52"  vs  your current 48 and the center pin is either an inch or 2 inch difference
Annihilation  Fabrication
Do you need a Hammer?
They are 52" eye to eye.  They have 2 more inches more length on either side of the centering pin.  So they would help your shackle angle but your wheelbase would get 2" longer in the process.  So for the love of god shorten your shackles and gain some lift in a different way!  9" is tooooooo long mang.  ;)
CTENG in KS
Quote from: WHITE_TRASH on April 18, 2005, 01:08:14 AM
Amen, brotha!
86yota
Thanks for the info Iron Clad and WT.  I think I would like to lengthen my wheel base a little anyway.  Off to the junk yard.  As for shortening my shackles I think I will refer to Iron Clad on that.  Your old ones were about that long correct?  Do you still run them?  What do you think?
IronClad
you gonna run these in the rear aye ?  i ran a 8" eye to eye shackle previously
86yota
Yea, These are on the rear?  They are actually 9" total so somewhere close to 8" eye to eye.  I don't see the harm in running an 8" shackle in the back.  ???
IronClad
thats what i ran..  i also ran a 8"eye to eye shackle along with a ford shackle  for a drop setup. works great  with flat springs since if you have the proper angle  it will droop quite alot. run em !
dirtyskivies
theyre 51'' and the center pin is 21.5'' from the front eye
the 87's are 48'' and the center pin is 20.5'' from the front eye
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
86yota
That should come out about right then
