How do you use it? I’ve read on some other post on this site some guys take the timing chain off and let it jam the crank. Have you done this method?
DON'T TRY THIS METHOD! I've heard of it and the damage it can cause. First thing to consider is the timing cover breaking. The chain bunches up and Houdini's itself out the side.Second is the crank snout going it's own way. Even if it does work, and nothing breaks you WILL need to change the timing chain, it's not designed for such use. The tiing cover will most likely leak. And the one thing that you will really hate is the crank snout bending and takiing out the #1 main bearing and saddle.Not worth taking the chance.
What moron posted on "this site" such an idiotic idea!! Gnarls.
No idea, but I had to put in my 2 cents. I don't really like putting a breaker bar on the crank snout and turning the engine over, but it does work. Not sure it's any worse than holdin the flywheel to torque the balancer bolt, but I do have my reservations.
Gnarly, the same could be said for rebuilding engines, sometimes things don't go like they should.I literally broke snap on tools using huge extension bars.....am i dumb?Maybe but fasteners don't always cooperate.CB
Started by Hyena Engine
Started by Kurlee Daddee Toyota Pickup/4Runner Tech 1979-95
Started by REG535 Newbie Questions
Started by 84Flatbed Engine
