2RZ distributor removal?
Started by toyodaaddict, August 24, 2021, 04:41:29 PM
toyodaaddict
I'm trying to remove the distributor on a 1995 2RZ. Is it just the two bolts that need to be removed? I've pulled pretty hard on it and I'd like to be sure I'm not missing something before I get too ruff with it. The FSM says to disconnect the distributor connector ( I assume this is the electrical plug) and then to remove the hold down bolts (I see two) and distributor.
RUGER
what yer doing sounds right. should just unbolt and slide out. id recommend putting #1 cylinder at top dead center so it will be easier to clock when you stab a new one in. i will say ive never played with the 2rz, just 22r so hope someone else can chime in that has experience with that motor.
RUGER :usa:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
toyodaaddict
Quote from: RUGER on August 24, 2021, 04:51:33 PM
RUGER :usa:
That's right where I'm at, never pulled a dizzy on a 2RZ. It definitely isn't just sliding out. I've got it set at TDC. Plan is to pull the head for a head gasket and timing chain. Engine is at 275K miles  :gap:
RUGER
have you tried a small prybar or screw driver.
RUGER :usa:
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
NRA life member
toyodaaddict
Quote from: RUGER on August 24, 2021, 05:17:13 PM
RUGER :usa:
I tried a screw driver, not too hard though. I did pull on it pretty good a few times. I want to be sure I'm not missing a hidden bolt or something before I give it the Macho Man treatment
RUGER
#5
maybe theres a hidden both. the only other thing i can think of is the dizzy is stuck with oil or crud, or you drained the oil and it dont have lube.
edit: unless there is another bolt prying on it should free it.
RUGER :usa:
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
NRA life member
toyodaaddict
Quote from: RUGER on August 24, 2021, 05:37:33 PM
RUGER :usa:
Shot some penetrating oil in there, let it sit and it came out.
RUGER
Awesome. Glad you got it out.  :thumbs:
RUGER :usa:
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
NRA life member
