Rims
Started by Wainiha, April 10, 2021, 02:41:33 AM
Wainiha
Who is running what?  I'm interested in a new set.  My socks are 16" ...I'd go to 17" but not larger. I'd like good looks but strength and fitment is the priority.  Anyone try the Method Trail series with the "knurled" edge?
Not opposed to beadlocks but I want 5 and that =$$$
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
idishert
They have a nice selection of Method Wheels in 17's on 4wheelonline.
mudmaster
I'm running Trail Worthy re centered H1s double beadlocks.
Time to go wheelin!
MotioncontrolMike
Don't you need to be concerned about the right backspacing to fit properly with RCLT? Maybe you already have considered that. 4.5" or less...
Mike
TacoEspecial
I'm running icon rebound pros 17x8.5 and 4.75" BS and a 1/4" spacer cause I need 4.5" BS for my RCLT
Think these are great rims
Kinda wanted a true headlock but also wanted dot approved and nothing really heavy
These are 28# and made stronger than standard icon rebounds and have the bolts that hold the outer bead
These are load rated 3200#
Balanced with an oz or less with my 37" geolanders
$360 ea and in stock
Only have 150mi on them so far
MotioncontrolMike
Taco- those look terrific! I was hoping not to have to add a spacer, but if I need to, I will- as I have done so in the past. Currently I have the SCS BR6 rims and am concerned these will not hold a bead as well in low pressures as a bead lock or the Rebound Pro. You got me reconsidering the Icons for sure!!!
Mike
TacoEspecial
Quote from: MotioncontrolMike on March 03, 2023, 10:17:58 AM
Mike
You could try'em and see
My steel 16" and Toyo's surprised me all the time
But I didn't do much extreme stuff
