1995 4runner original manual sr5 4x4 SOLD
Started by Kawivannoy, November 08, 2020, 04:02:10 PM
Kawivannoy
1995 toyota sr5 4runner 5 speed manual 3.0 4x4 IFS with a completely new long block with Japanese OEM spec parts. Crankshaft ground and polished, bored and honed block, new crankshaft bearings, new pistons, new connecting rods, new valve guides, new valves, new cams, recut valve seats, updated head gaskets, all OEM seals used. See pictures for the work that has been completed on this. Very very clean and not another one this nice on CL. $7500 obo clean Nevada title. No accident history. Has all the original fenders with VIN tags. Located in Reno, NV open to all trades, let me know what you have of similar value.
273,xxx miles with about 3,000 miles on the new engine. Below are all new parts installed in the last 3,000 miles. All receipts and stock parts before lifted will go with it.
New OEM Speedometer cable, OEM throttle cable, LCE short shift kit, new carpet with sound proof barrier, 5" rough country lift, "OME" old man emu torsion bars, 17" aluminum method rims, trail gear wheel spacers front and rear, all new ball joints on front end, new front cv axles, everything under the hood, i mean everything and with OEM parts no junk! Clutch, flywheel, Aisin clutch master cylinder, Aisin brake master cylinder, Aisin clutch slave cylinder, 4 hole chevy fuel injector conversion instead of single hole which is stock, better fuel atomization, fuel economy and cleaner burn in the combustion. LCE headers back crossover exhaust system including Magnaflow catalytic converter. The crossover exhaust below the transmission fixes the issue Toyota had running it over the top of the transmission and causing a big heat difference from the front of the cylinder heads to the rear of them making a warped head over time and leading to coolant leaking into the cylinders. Common on the 3.0's along with the head gaskets that were used as well by Toyota. Toyota had recalls for this and were replacing head gaskets if no cylinder damage, replacing the complete engine and installing a different crossover above the transmission that was pushed back further away from the cylinder heads. New Denso O2 sensor, manual Aisin locking hubs, new aluminum heater core Napa, new heater valve on the firewall OEM, HPS silicone hoses, blue top optimum battery with billet aluminum tray holder, Denso OEM ac compressor, Denso oem condenser, electric fan assembly, billet fan spacer with flex fan from LCE, Napa lifetime warranty alternator, Napa lifetime starter, Autozone lifetime power steering pump, OEM thermostat, radiator, HPS complete air intake, washable filter, new spark plug wires, new distributor cap and rotor, new OEM Denso fuel pump, fuel pick up screen and inline fuel filter, fuel pressure regulator, all new belts OEM, new timing belt tensioner, new fan shroud, new oil pressure switch, new OEM knock sensor, new iridium spark plugs, new water pump, new oil pump. All fluids replaced. LED interior lights, LED hi/low beam headlights, bluetooth stereo. All lights work! No check engine light and runs amazing! Husky floor liners. I can get more pictures and video if requested. This is a vehicle ready for another 250k or more miles thrown at it! Im sure I missing some things. Come see it to get a better understanding how clean this is! NO RUST AT ALL!!! All windows controls work including cruise control. Test drive with cash in hand only. Serious inquires only. Call or text 7757373850 Thank you!
Kawivannoy
Photos attached and I can email or text better quality ones if requested. Thank you!
Kawivannoy
