I am rebuilding a straight axle on a Tacoma that has had a straight axle conversion by the prior owner. The housing was manufactured by Diamond and the axles are Longfield type probably about 8-10 years old. Unfortunately, when I bought the truck was unable to talk to the prior owner so I am having to figure out what parts were used.
Everything is torn apart and in generally good order but when I removed the axle from the Birfield joint on the passenger side I noted that the inner end of the axle is beaten up pretty bad. I used the pipe removal method where you drop the axle into a pipe to shear the c-clip. For some reason the passenger side was a real devil and it took 10 solid thumps to free the inner shaft. I used plywood to cushion the cage and under the axle shaft on the floor. I have no idea what damaged the inner end of the axle.
Can't seem to upload a photo.
The damage is at the inboard end of the shaft and there are a series of flats where it appears the shaft has contacted the Birfield housing.
My assumption is that if the cage accepts the axle without binding on the damaged area of the splines I can probably live with reusing parts as long as I don't find more damage to the balls, cages, etc due to metal filings in the works.
Tomorrow I hope to disassemble the Birfield and see if I can find corresponding damage to the housing.
Any advice is welcome.
