Ome hd springs sits low up front
Started by Eschenfeldt, September 17, 2020, 09:45:38 PM
Eschenfeldt
So I put a set of old man emu shocks and springs on my 1981 Pickup (front and rear) and after they have settled a bit the fronts it's a bit low, I'm wondering what I can do about this can I increase the shackle length or should I add a leaf? I'm already thinking about removing a leaf from the rear but I don't think that'll solve my height problem, but I don't really carry much weight normally so they're a bit stiff.
81 Toyota still figuring out what I want to do with it
Eschenfeldt
Drop hanger sounds like the correct fix.
toyodaaddict
Quote from: Eschenfeldt on September 18, 2020, 09:26:25 AM
Probably not a bad way to go. I'm pretty sure a drop hanger is required to fit high steer with the Emu springs.
Eschenfeldt
I'm glad to hear that I might be able to do high steer with my ome Springs because I thought I had screwed up And would need to get new springs to fit high steer. I assume when adding a front hanger you would also want to get longer shackles for additional lift and to keep the front pinion angle Somewhat in spec?
toyodaaddict
Quote from: Eschenfeldt on September 18, 2020, 12:33:07 PM
Helipilot and Zippo both made high steer work with emu springs. Both awesome rigs.
https://board.marlincrawler.com/index.php?topic=96772.420
https://board.marlincrawler.com/index.php?topic=98969.0
