Old SR5 wheels on 1st gen Tacoma
Started by redewenur, April 27, 2020, 08:30:07 PM
redewenur
Hello I just found some old sr5 wheels and wondering if these would fit my 2002 Tacoma extra cab 4wd.  Anyone could please answer this question and if anyone has any pics, I'd appreciate it.
I have stock suspension and would like to put 31x10.5r15 tires on them.
gnob
Do you have 15s or 16s stock?
Some wheels don't fit over 16" brake caliper, which you probably have.
hold this. . .
redewenur
I have 15s stock.
emsvitil
There's two versions of those wheels.    They have 2 different offsets.    The slightly older has 15mm (mine) then I believe the other is 8mm
It's on the wheel next to the 15x7JJ marking.   (Make sure they all have same offset)
What's the size and offset a 2002 Tacoma wheel?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
redewenur
These are the exact wheels I picked up
redewenur
Does anyone know for sure? It seems that it should fit because of the calipers, but does that mean the wheel will be more in the wheel well than out?  I haven't physically tired to put on truck yet
emsvitil
Is the picture the SR5 or Tacoma wheels?
If Tacoma, what's on the SR5 wheels?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
redewenur
That's on the sr5 wheel
emsvitil
You need to compare to Tacoma wheels.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
redewenur
So I finally got around to test fitting.  They do not simply bolt right on.  Most likely will need wheel spacers
