20r kits
Started by Oceana, March 08, 2020, 09:45:26 PM
Oceana
looking for good quality rebulid kit for 20r
been searchin but havent since much at all
zippo
Call Jim at 22rePerformance.com best guy in the busines.
If you see it, its for sale.
H8PVMNT
#2
Everything in the bottom end is the same as early, dual row timing chain 22r except for the pistons and rings.  I used pistons and rings from an outfit called Evergreen for the 20r because thy were made in Japan.
The head has different valves.  Rockers, valve springs, guides, valve seals, cams and rocker shafts all cross over he same way from early 22r.  By early I mean '81-'84 22r stuff in general.
Here is my recent 20r build...  https://board.marlincrawler.com/index.php?topic=102500.0
I used some DNJ stuff.  I don't think there is anything wrong with the bearings and hard parts but I have found the seals and gaskets to be second rate stuff.
– Steve McQueen
Gnarly4X
Quote from: H8PVMNT on April 01, 2020, 10:22:57 AM
I have a lot of respect for H8PVMNT's experience and knowledge.
However..... knowing what I know now, the ONLY DNJ part I would consider using is the bare head.
And in that case, as a current source, only "approved" by my local cylinder head shop.
Buying a head from 22RE Performance would be my first choice.
Especially on a head!!...I believe compromising quality or reputation for price will come back to bite you.
Gnarls.
