Marlin 1600lb clutch kit year questions
Started by Osage1978, November 26, 2019, 06:40:41 PM
Osage1978
Long story short I have a new 1600lb clutch kit still in the box ( MCCL-123H ) it says 1981 - 1988 but I'm going to building a newer 22re for the 1982 truck. Will it work if the engine is newer than 1988? Transmission that'll be going in is M/C L52HD
Edit: I can't find what the difference is if I use the a pre 89 flywheel, what's the difference that happened to the 22re in 1989? Tried searching the www. to no avail
John 5:24
:)bestgen4runner
I recommend calling Marlin and talking to them. They are good with this swap info and will give you a hard answer.  :turtle:
I am 1/5th of Perfect Fit
Osage1978
Thanks, I had contacted them & actually just heard back from them just a few minutes ago and they said I was good to go
John 5:24
T-Revv
The only difference between the 81-88 and the 89-92 clutch is just the throw out bearing.  It was in two pieces in 81-88 (with the cast iron collar and a bearing), where as in 89-92 Toyota started using a one piece bearing that came with the collar manufactured in.  They are the same size bearing and can be interchanged with no problem.  93-95 they did change the size of the clutch and flywheel to 9 5/16 from the earlier 8 7/8.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
HappyTruck
This leads to the question... can I use the new one-piece style throw-out bearing with the manufactured in collar in place of the old two-piece design?
Thanks for your reply to this old conversation.
HappyTruck
