Truck Tires Allignment
Started by 854x4, April 11, 2005, 07:12:52 PM
854x4
I recently rebuilt the front axle on my 85 toyota truck. I have noticed that the tires are starting to angle in at the bottom.Can this problem be corrected with shims on the knuckle if so do you put them on the top or bottom? I used the old ones when I rebuilt it.I have also installed 3" over stock shackles on the front along with my 3" lift springs can this be the problem? Thanks for any help.
1985 Toyota X-Cab 22-RE 4.88 gears Detroit Locker Rear, Open Front 4 1/2" Lift 32x11.50 BFG Mud on 15x10 rims. LC Rotors, 92 IFS Calipers,MC,Dual Diaphram Booster.
86yota
Just set the toe.  There is no reason for camber to change is a solid axle truck.  I'm sure your caster is way positive from the shackles but as long as its close to even on both sides it should not effect tire wear.
854x4
What is toe and how do you set it on a solid axle truck?
86yota
If your looking down at the top of your truck and the tires are pointed away from each other than it is toe'd out.  Oposite would be toe'd in.
        Top view
Toe is set at the tierod ends.  You can usually get it close with a measuring tape but to be truly accurate go to an alignment shop.
Makohon
toe is... well ummmm think of someone that is pigeon toed... thats toe in... and toe out is the opposite... camber is... well think of somthin vertical ''like your tire'' and when its not all the way vertical your camber is messed up... u get it??? :wave:  :beerchug:
Makohon
86yotas got it... just posted right before i did :wave:  :beerchug:
854x4
If your looking at the front of my truck the bottom half of the tire is more in then the top half.
  Front view \ / Its like that if your looking at it from the front that is what I want to fix. Its \ / instead of  l l  like it should be.
