smog junk on 22RE
Started by awhotrods, April 11, 2005, 05:13:04 PM
awhotrods
I am in the process of converting my 82 yota to a 22RE.  I want to get rid of as much smog junk as possible.  Does anyone know what or how much of the stuff I can remove while keeping it running good?  Thanks for any info  :wave:
Weldo
You can remove the air injection if your motor is so equiped.  It goes from the air box, through a small black plastic pipe.  then it feeds into a round plastic bulb on hte passenger side of the motor.  It follows through some tubes and pipes around the back of the head and I think it goes into the head and exits through littlte pipes above each exhaust port into the exhaust manifold.  I'm sure you can remove hte EGR valve too, but I don't know much about that thing.  I bet you can remove just about everything as long as you plug up the holes so you get no vacuum leaks.  It might be a good idea to pick up a Haynes or Chiltons manual.  They map out all the emissions crap pretty detailed, might help with your tear down.
