Toyota Pickup 14” king 4 link build everything new $16,500 Reno Nevada
Started by Kawivannoy, February 13, 2019, 03:00:17 PM
Kawivannoy
Reno, nv 1980 toyota pickup $16,500 obo
Call or txt for pictures 775-737-3850
I have a 1980 first gen toyota pickup recently built. STREET LEGAL. Clean Nevada title. 72,000 original miles on the truck. Re painted. All gauges function on cluster. Speedometer is acurate. All parts are brand new with about 4,000 miles total on the truck since built. Finished building this about a year ago. Mayhem metal works 3 link front and 4 link rear. Full center skid protects everything. Unbolts and drops down to access transmission and transfer cases without unbolting the links. 14" king coil overs front and rear. Rear disc brake conversion. 17" method bead locks. 37x12.5 open country toyo m/t tires. Full size spare held in with a T handle threaded cone. Long field axles front and rear. Yukon 5:29 gearing. All oem seals/gaskets throughout everything. No junk parts store stuff. Lighted whip. Aluminum radiator. Drive lines front and rear by Driveline Specialties. Drive line e brake kit that uses the oem toyota parking lever. Marlin crawler 5 speed transmission. Wider toyota rear axle. Marlin short shift. Trail gear dual transfer cases with twin sticks. New LCE 22r engine. Holley sniper 2300 efi kit. LCE single plane intake manifold. Single wire chevy alternator. Marlin crawler 1600lb clutch and flywheel. Aisin clutch slave cylinder. Stainless steel braided clutch line. Aisin clutch master cylinder. Aisin FJ 1" bore brake master cylinder. "No need for the proportioning valve" Brake calipers and rotors matching all 4. PSC hydro assist. High steer. Trail gear IFS steering box. Trail gear 6 shooters. Eaton detroit truetrac helical gear lockers. Davis Unified electronic ignition distributor. Live wires. 1650psi trail gear steering pump kit with cooler. Warn locking hubs. 10,000lb winch. All koyo oem bearings used. Spray in bed liner. Limiter straps. Red top battery. Trail gear built in battery tray. 5 point crow harness's. Clutch brake pedal rubber pads. Oem dash with dash mat. Limiter straps. 20gal aluminum fuel cell. High lift jack/shovel. Full exo cage 1.75 .120 wall. Smiley face bottle openers. Heater in truck. Tacoma electric heater valve on/off. Lolly pop purple powder coating on engine components and links. All window trim/seals door seals replaced with oem. Removable rear camping rack that also holds mountain bikes. I have $38,000 in parts alone put into this truck. All receipts are in a folder organized. $16,500 Serious inquires only.
Willard
Kawivannoy
gcabibi
