Engine mounts
Started by csdpower, February 26, 2003, 09:56:04 AM
0 Members and 6 Guests are viewing this topic.
csdpower
I ordered a t/c w/4.70's and I'm researching ways to keep from tearing my engine mounts. has any one tried the engine mounts from LC Engineering?
http://www.lcengineering.com/Chassis.htm
are they as good as they look?
any other suggestions?
brainlessfool
#1
Well they do look good!:yum: :drool:
mr4x42u
#2
I know alot of people use a chain to the top of th mount then weld it tight so that it only gets pulled on when needed to keep stress down on the mount..I have not had a problem yet.. :up:
Cracker
#3
Scott Ellinger has some nice ones....
http://www.rockstomper.com/
Art
99 Taco
80 Hilux - 20/22R Hybrid, Dual Mikuni's, R151 trans, Budbuilt X-member
74 FJ40 "The Project"
derek
#4
im using the rockstomper mounts. they add a little vibration to the truck, but its not too bad. got sick of tearing up mounts. i had replaced 4 before i put them in.
derek
drybone
#5
don't go with the L.C's unless your desert racing,  I had them and they rattled me out of the truck,  I mean it shook so bad I couldn't even turn up or down the stereo, should you ever go to dual crawlers, the extra t-case mount will make a difference.  Let me know if you come up with anything, I'm looking for something different.
Not just another ROck KRAwler.
Ever been to Dry Bone Falls.
mr4x42u
#6
Quotedon't go with the L.C's unless your desert racing,  I had them and they rattled me out of the truck,  I mean it shook so bad I couldn't even turn up or down the stereo, should you ever go to dual crawlers, the extra t-case mount will make a difference.  Let me know if you come up with anything, I'm looking for something different.
Thats why some are using a chain..You still can keep you stock mounts but have extra strength while the engine is under a heavy load such as crawling...
Squirrel_4_life
#7
where exactly is the chain? do you have a pic for reference. I just put in new toyota mounts and they provide such a better ride than rockstompers and i don't want to tear them as they are not cheep.
85 x-cab, 22re, welded rear, 5.29's, marlin high steer, front axle forward 2", rear moved forward 9", ARB hilux bull bar, flatbed and 37's on the works
mr4x42u
#8
Yea,,I have a pic somewhere..The chain would go on top of the motor mount to the frame..You only want it long enough so that when x-amount of tension is put on the motor mount the chain gets tight and the motor mount can't pull any further..I;ll find that pic...
Dirty_Harry
#9
Roger Brown details this on his website.  I chained my motor mounts and am also using a transfer case crossmember from Front Range Off-Road to limit excess torquing of the drivetrain.  I don't have much room between my steering shaft and turbo housing and I do not want them coming into contact with one another.
________________
Harry Wagner
86 Turbo Truck
4x4Wire's Toyota Section
mr4x42u
#10
thanks dirty harry,,that will work..could not find my pics..
5spd
#11
I have duals, 175-1 and chained the frame to the engine block next to the engine mount, there are 3 or so holes for a 14 mm bolt tapped there for mount locations. I also have a bud xmember with dual tranny mounts, has worked great to this day and not one broken mount.
trt2
#12
I used the chains and still broke them.
I'm running an AOR mounts and they do give a lot of vibration...
for full trail use, go with the aftermarket mounts and forget about it...
for 80% street, 20% off road, go with chains.
Tony
Round Up M.C.
mr4x42u
#13
Thats becaue you can't use gold chains for the BLING BLING!! :psss: :beer:
superstarai
 When i put rockstompers motor mounts in they did not fit! On a 85 extra-cab with auto and 22re engine damm company anyway. I will never buy from them again! :mad:
kyle_22r
i've heard the rockstomper mounts are best when you only use one, and use a stock mount on the other side.  i've heard of fitment issues when using 2 of them
superstarai
 Yea i only got one side to go on not good. They need to fix it and make it better i think.
84runner
I am running a set on my runner and there were nothin short of a pain in the  :moon: to get on . And you definently get some more road vibration out of them and they seemed to lift the motor a little higher than stock. But know problems yet  :crossed:
