No fuel to carb
Started by MNR, November 22, 2018, 12:35:42 AM
MNR
I have installed a new sending unit,found and fixed a plugged hose, new fuel pump, took fuel tank out And it's ok. But when I prime the carb it starts just  until  that's gone then died and will not start. No gas making it to the carb. What next? Any suggestions? :attention:
300k
If you pop off the fuel line going to the carb from the fuel pump (this is the one on the head that runs off the camshaft, correct?), is there fuel there?
This is a common no-start fix, after you removed the fuel tank, did you put more fuel in it?
OVRAROK
Is it possible that you installed fuel lines incorrectly at the pump. :dunno:
MNR
I going to try going to an electric pump,I'll wire it up to the safety switch that goes to the oil pressure port, not going to run a regulator. Figure out the fuel line routeing and call it good wish me luck.
