So this combination is not compatible?
The chain that was working has 98 links. The chain came off(jumped) the top sprocket & went to the back side of the sprocket. I did take a look at the engine block, it does have the thing on the block that is circled. It has 22R stamped in the small area beside the block number(serial number)?
The latest information I have is the head is a 1992 model & the block is 1983 model.
that is physically not possible. The 83 piston would smash into the bottom of the 92 head the first time you tried to crank it and would either stop cold or shatter the head and/or piston. If you drove this even 5 minutes it absolutely has to be a 83 head and a 92 block. and even then it would run like .
What if it were an 83 block with >85 pistons and a 92 head? Would that at least permit it to turn a full revolution without piston-valve contact?
Out of curiosity, is there a year model head that will work with the block that it is in the truck? One person on here said it would. Instead of pulling the engine out I could replace the head. It would save time & money. Thanks
Okay. I'm not sure when I'll get to do that, but will try.
:outtahere:um, well. maybe. i'd have to scratch my head on that a minute
I live in south Mississippi, about an hour north of the coast.
Started by 2utadud General 4WD Discussion
Started by GoaT Engine
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
Started by chevihemi Parts For Sale
Started by 84pickup Toyota Pickup/4Runner Tech 1979-95
