New to the forum but not new to Toyota's
Started by yotalight87​, December 27, 2017, 11:28:09 AM
yotalight87​
Figured I need to start posting to the forum as I'm seeing the need for the Toyota community. I have an 87 SAS 4runner. Dual cases, 529's, lockright's, chromaly shafts front and rear. Just broke my Passenger front axle. I had the old birfield eliminater Dana 44 u joints. Working on replacing with Longfields or the RCV 300m ones.
When I broke my axle as I backed up I broke my hub also. I'm on the lookout for an Aisin hub Ft-005. I really only need the outer cover with the 2wd 4wd selector knob.
Sent from my XT1254 using Tapatalk
Slabzilla
 :welcome:  Go for the RCV's, unless you can find some OG Longfield's.   :crossed:  The thing they don't tell you about the Birf eliminators is that the u-joints don't take that much more angle than the Birfs, they just don't have that small spline neck down of factory Birfs.   :turtle3:
yotalight87​
Quote from: Slabzilla on December 27, 2017, 03:36:29 PM
Yeah I made the mistake of not having my stops adjusted too so I think I was at a pretty hard angle. I bet the u joint bound up. Does anyone have the hook ups on Aisin hubs? That's what was the most disappointing is I think the axle  pushed out on the hub breaking it. Cause all the gears inside are fine.
you need just the outer part, with spring, ball,o ring, and selector? im sure i have it
Agree with the RCV recommendation as it is the original Longfield design.  Trail Gear bought the brand name but uses a different design that while super strong isn't the proven product that the RCV is.
I think I picked up some hubs from Yota Yard in the past that's located in Denver, CO.  If memory serves they were about $50.  You can purchase online, but if you can find a forum source you'll most likely come out ahead.
yotalight87​
Has anyone used the new Aisin hubs from Marlin or Trail gear? Are they just as strong?
