Bad 22R motor mount? Harmonic balancer?
Started by Toybrota, August 12, 2017, 11:32:09 AM
Toybrota
Went on a super bumpy road yesterday, and after leaving that area my 85 pickup vibrates at 1500 RPM.
Aside from that, the motor doesn't seem to sit straight up in the engine bay, a quick glance at the mounts didn't show that anything is wrong.
Is it possible it's something else?
Sent from my Nexus 6P using Tapatalk
Toybrota
Motor seems off center.
Toybrota
Found the problem. Pretty sure there is supposed to be bolts on the Tcase mount.
Toybrota
Turns out that wasn't the problem. I'm guessing it's just the motor mount.
Bad_Vision
Probably. You only have those three mounts so if the tcase one is good then your left with engine mounts or possibly a u joint.
Sent from my XT1635-01 using Tapatalk
Toybrota
It was a broken mount, got a replacement and it's running good. Radiator shrowd is garbage now, but that's what happens.
