Author Topic: 22RE strange Temperature/ temperature spiking issue?  (Read 19102 times)
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,254
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Well I haven't made any progress due to needing to do some unexpected work to the 84 DD.  But, I talked with Jerry at 22REPerformance. After telling him that I replaced the radiator with a new aftermarket unit during the rebuild, he suggested I try another radiator before getting the dual stage thermostat. He said that the aftermarket radiators are assembled so sloppily that its not uncommon to have dead spots due to cores being soldered closed. So I guess its off to the junk yard to try and find an OEM radiator to have reconditioned  :crossed:
Based on what you described, if the radiator is defective and not fully flowing and cooling, it should result in a constant elevated operating temperature.  In other words, if all else is normal, you have a new factory thermostat, if the radiator is restricting flow, the coolant temperature would go up and stay up.
The standard Toy factory thermostat begins to open at 190d F.  It is fully open at 212d F.  So, if you see a very short – a few seconds – spike on your temp gauge to 200d F, that could be normal.  If, after a normal warm up, you see a constant elevated temperature, say above 200d F, then you might have a restrictive flow issue.
If all else is normal, keep in mind that if you have a 13 PSI radiator cap with 50/50 coolant/water, the coolant would not boil until around 260d F (depending on your actual elevation)… slightly above your average engine oil normal operating temperature.
As long as the engine temp on your gauge is not running constantly above 195, I would not be overly concerned.  Also, I think that a freshly rebuilt engine could have a slightly higher coolant temp due to the excessive friction during the initial break in period.
If you want to eliminate a possible bad thermostat, remove it and take your truck for a healthy test drive.
That's just my opinion - it may be worthless.
Gnarls.
« Last Edit: Jul 12, 2017, 04:43:11 AM by Gnarly4X »
toyodaaddict [OP]
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
I had a chance to mess with the truck today and think I eliminated the radiator theory.
I started the truck up cold with the heater temp switch on cool and went for a drive. The temp stayed around 180* for 20-30 min.
Then I moved the heater switch to warm and the temp quickly made its way up to 190* and then back down to 180*, but would fluctuated between 180* and 190* on acceleration and deceleration. When I put the heater switch back to cool the truck ran steady 180*
I took the truck home and let it fully cool down. Then I started the truck up cold with the heater temp switch set to warm this time and went for a drive. At roughly 1.5-2 miles the temp reached 200* and before it could get any hotter I flipped the heater switch to cool and down it came to a little under 180*
This is some weird stuff and I'm not impressed.  Time for the 2 stage thermostat I guess  :dunno:
Gnarly4X
  • Male Posts: 4,254
Hi toyodaaddict,
I think I’m a little confused.
Typically, the heater lever simply opens and closes a manual valve that allows coolant to run through the heater core for heating the cab.
If the lever is in the “warm” position, the valve should be open and the heater core would be absorbing heat from the coolant – which normally lowers the engine temp on mechanical gauge.  This is the opposite of what you posted is happening.. unless I’m reading it wrong? ….
“When I put the heater switch back to cool the truck ran steady 180*”
….“but would fluctuated between 180* and 190*”…. It is normal for the engine temp go up on acceleration and down on deceleration.  How much is abnormal on the gauge is questionable.
Since the temperature will run steady at 180, I don’t believe this is thermostat related.
It appears the change in temperature is related to the heater valve and heater core.  Its almost as if the coolant tubes are switched or something is blocking the flow when the heater switch is moved?
Obviously, even with the heater core valve shut off, the engine temp should NOT go up excessively.
I’d get a coolant flow chart/diagram and make sure all coolant tubes are connected correctly.
Here’s a post on our site I found that may or may not help.
http://board.marlincrawler.com/index.php?topic=63219.0
Gnarls.
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,057
  • Member since Dec '03
  • Crawlin with Marlin
The part that makes no sense to me is the temperature fluctuation on acceleration and deceleration. Fluid cannot change temperature that quickly.
Gnarly4X
  • Male Posts: 4,254
.... I think you need to perform a combustion leak test on the cooling system. I guess it could also be a small crack in the head or block at a coolant passage
I agree.
Gnarls.
Gnarly4X
  • Male Posts: 4,254
... Fluid cannot change temperature that quickly.
Well... that depends.  :gap:
Gnarls.
toyodaaddict [OP]
  • Male Posts: 1,145
Ok now you guys have got me in panic mode  :yikes:
Any chance any of you Washington guys know a shop that can do the coolant/exhaust gas test that's familiar with the 22re? I'm in the maple valley area and have yet to find anyone that is very familiar with these engines.
Gnarly4X
  • Male Posts: 4,254
Don't panic yet.
Gnarls.
blackdiamond
  • Male Posts: 5,057
I don't think this is intended to be a joke, but I suspect we might be able to recommend a place...
blackdiamond
  • Male Posts: 5,057
Gnarls.
Always, but I'd suspect that if the temperature is fluctuating quickly it's more of an indication that the flow by the gauge is from a slightly different source rather than the average temperature of the fluid cycling.  It's even less likely for it to cool back down that quickly.
toyodaaddict [OP]
  • Male Posts: 1,145
you can get something similar to this https://www.amazon.com/Block-Tester-BT-500-Combustion-Leak/dp/B06VVBSFTF/ref=sr_1_1?s=automotive&ie=UTF8&qid=1500055099&sr=1-1&keywords=combustion+leak+tester
however any shop could perform the basic test
Thanks, I wasnt sure if the kits where reliable or not. I'll probably pick one up. Would I be correct to assume a shop would use the same method to test for the combustion gas?
Well lets hear it, am I missing something obvious here?
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
There is a Toyota Master Tech that lives in Maple valley, Washington.
He is a Legend around here. They call Him Toyota Chris. You might have heard of Him.
I know him well and could talk to him for You.
He does not work for free, but is a great guy.
I think He also is a marlin Crawler Guy. What was his user name again?
Many of the guys on here Know him well and would recommend him very highly.
I am 1/5th of Perfect Fit
blackdiamond
  • Male Posts: 5,057
Sounds a bit like the rum and Coke has not quite worn off completely...
Gnarly4X
  • Male Posts: 4,254
You guys are going to have the OP on drugs pretty soon!!!  Stop it~\!
Gnarls.
toyodaaddict [OP]
  • Male Posts: 1,145
in case all this sarcasm is misunderstood, reach out to :)bestgen4runner aka Chris. He lives in your area and is our resident Toyota mechanic
:)bestgen4runner is on board for next week :thumbs:. Hopefully we will NOT be reporting anything catastrophic.
:)bestgen4runner
  • Male Posts: 1,796
Challenge accepted  :thumbs:
Gnarly4X
  • Male Posts: 4,254
I will be patiently awaiting the diagnosis
Me 3....
Gnarls.
blackdiamond
  • Male Posts: 5,057
Catestrophic equal lucrative!  It's all a matter of perspective.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Drill an 1/8" hole in the flange of the old thermostat, install it and see what happens.
It will take longer to warm up, put there will be constant flow thru the thermostat................
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
  • Male Posts: 4,254
I don't believe that will have any affect on the temperature spikes. :dunno:
Gnarls.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Gnarls.
It will simulate the 2 stage thermostat to some extent.......
And if the spikes stop, we've learned something  (although what we do with that knowledge............)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Stupid question.........
Do you have the thermostat installed upside-down?    If so, the wax pellet would be on the hose side (cool side) of the thermostat............
You would get the overshoot with it installed that way.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
toyodaaddict [OP]
  • Male Posts: 1,145
The Thermostat is installed with the spring/slug down. The 2 stage thermostat is on its way, so I will be able to give that a try.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
  • Male Posts: 4,254
... The 2 stage thermostat is on its way, so I will be able to give that a try.
I'm anxious to read about the results.  I hope it fixes your spikey temps!
Gnarls.
Last post Oct 03, 2002, 04:54:37 AM
by drybone
Last post Aug 17, 2008, 08:31:12 AM
by 79coyotefrg
Last post Feb 08, 2011, 02:28:38 PM
by emsvitil
Last post Jan 24, 2020, 04:45:11 PM
by arlindsay1992
Last post May 08, 2020, 03:54:10 PM
by CheapHeap
