Have you considered a colourtune, it goes in place of a spark plug and is made of pyrex allowing you a window into the chamber and thus the colour of the burn?
That product has been around awhile. I doubt that it is used by any serious "tuner", as most people probably have never heard of it. Does anyone know someone who has used it or using it now to "tune" for AFR?I'd rather spend the money on a cheap AF gauge. Gnarls.
If I can get this thing dialed and then maybe learn how to do side drafts I will be the Bob Ross of Toyota carbs...
I don't know where my secondary is at as far as rich/lean but I can pull on hills I could only maintain on before when I use it.
You know you have them days when you wish you ad kept your gob shut
Interested in your results. I had one on my 85 Nissan Naps Z 4x4. It ran good, and gave me a best of something like 28 mpg on a run one day. I had 30's, and drove it hard. And it ran good off road. And my favorite was climbing steep hwy passes, down shift and put your foot to it, and the secondary would rip. The only issue I had was in the spring and fall, I had to adjust the choke, and idle. But overall, it was 1000% better than the Hitachi POS that was on there.
I hope you don't mind me documenting my weber tuning stories as well so we can keep the information in one thread! I have received and installed my 140 main jets (with 170 air correctors), it runs perfect in all conditions except for full throttle below 3500 rpms. It is pig rich. So rich that my a/f gauge doesn't even register, it goes to 9.0:1. Is it only the main circuit that controls WOT at low rpm? After 3800 rpms it is nice and steady at 12.5:1 and pulls hard up to 4900-5000 rpms, I guess it is at that rpm that the air correctors aerate the main circuit to lean it out. I think I will take my f50 emulsion tubes and solder some holes on top and drill some holes in the bottom to lean out low rpm WOT, I don't know if it will work but I'll try! If it doesn't work i'll try 130 mains and 150 air correctors.
H8, have you tried to run the distributor off of manifold vacuum and not ported vacuum of the carb?
Fine with me. The more information the better. What is your engine setup and your typical day to day elevation, etc?
He said he was at 160ft, and up to 1,300ft, so pretty low elevation. I am just learning this carb, but so far the one thing I have learned is to make just one change at a time. It's really tempting to change air correctors while changing jets because you all ready have the top off, but when I did that I made too much change and didn't know which change made me too lean.If I were you I would start by changing just the main jets, one step at a time and see what happens. Supposedly the air correctors are only in plat at higher RPMs, but I don't know for sure without an AF gauge. After you mess with the mains and note changes and get them where you want, then change the air correctors and see if leaner ones help your WOT problem or not. If they make a difference then they are in play at lower RPMs after all.I was reading on a Datsun forum about guys messing with the emulsion tubes on these, so I think you are on to something there. I'm not ready to dive into those until I get my secondary dialed in and get an AF gauge . If you do it please post the results and what it did to your AF so we can learn more.You should start a Weber 38 thread since it's a bit different and you have to change both sides at once.
.... My dream is to break 16 mpg on the day to day with the Weber.
Haha, that's the problem with carb/engine mods and getting more response and better acceleration. You tend to want to enjoy it and it's harder to stay off the throttle .
and felt that exhilarating little adrenaline rush!!
Started by H8PVMNT « 1 2 3 4 » Project Research and Build-Ups
Started by Cheesemaker Chit Chat Camp
Started by knucklebuster Parts For Sale
Started by H8PVMNT « 1 2 » Chit Chat Camp
Started by H8PVMNT « 1 2 3 » Chit Chat Camp
