so i have a 4 door v6 6 speed 4x4 tacoma that keeps leaking from the timing cover so i have repaired it 3 times and now have bought a 2002 jetta tdi that i want to swap into it but i cant seem to find any adapter plates to go from the tdi to my R-A60 manual transmission. Everything i find is on a first gen tacoma 5 speed so i guess my question is my R-A60 bell housing the same as any other like the older 5 speeds? or has anyone seen or herd of an adapter plate for what im looking to do?
what thickness would you suggest for the steel? Ive seen some videos on using plexi glass as a template so i may just try it. so what else do you think ill run into? ie fly wheel clutch etc? thanks for the help
hey i cant thank you enough buddy....... also could you throw me a couple measurements off of your front mount i seen some pics and it looks great. why doesnt anyone use the vw factory motor mount block ...... the aluminium one with the 2 bolts?did you wire everything yourself? i found someone to make me a harness but i have to mail him both harnesses and itll be almost 1500$ to make a stand alone system with the malone tune so i was just wondering what your thoughts are on that?
your the best thanks for all the info im gonna hit up the you tube and check out the wiring to see if this is something i could figure out. I should have a daily driver on the road this week and can hopefully start ripping the 05 tacoma 4x4 6 speed apart..... the tdi is ready to go just have to do the delete and what not..... why isnt there any second gen tacos with the tdi? i cant seem to keep a timing seal in my v6 and its just as hard on fuel as my 1 ton cummins
still no 05 to 2015 tacoma tdi swapped .....
and dont get me started on the 4 bt lol i drive an 07 cummins 5.9 but again the price is realisticly 15000$ by the time your done and you still have an old beat up 4bt out of a bread truck or saw mill
i watched your build last night on youtube...... i lost it when you were driving that around......unreal how pumped you actually were..... i think ill do the plexy thing and make my adapter that way..... drill the flywheel to match bolt it up and weld the mounts up where ever they fall.. and maybe use the tdi fans with my rad if i could make it jive
hmmmm i may have to do the same if i dont have enough length..... i could maybe fit it between my grill and my current rad location. The starter is on the driver side going into the trans so that makes things easyer does it not?
yeah for sure it definitely doesnt like the idea... theres a hard line going to the turbo area and a steel antifreeze line that raps around the engine that i think is for the heater core but if possible would make the rest of the project go easier i hope. I still dont know if i have the wiring figuered out yet but i have a bunch a notes and a good head start so i think i will start ripping the tacoma apart tomorrow
Started by thepinktaco Parts Wanted
Started by 75 toy Parts For Sale
Started by malodin General 4WD Discussion
Started by PickleRick Transmission/Clutch
Started by Ku_Guy Project Research and Build-Ups
