Author Topic: Can twin sticks be installed without removing the T cases from truck?  (Read 8661 times)
fasterspider
  • Turtle Points: -2
  • Male Posts: 278
  • Member since Apr '16
You read it above, can it be done without pulling the T cases out of rig?
I am not afraid to cut the tunnel out of the way because it needs to be fixed after chopping holes for third shifter handle anyway but, at the same time I'm not against pulling the T cases, it's just a PITA.
fasterspider, now older and slower.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
I am going to say no, but you may have to take the x-member off and drop the back down to in order to get to the inner-lock pill. TG twin-stick, hope they have fixed them so the shifter arms that go into the t-case no longer break off. There are much better quality products out there!!
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,053
  • Member since Dec '03
  • Crawlin with Marlin
I think it's technically possible, but retrieving the pin might be tricky and really difficult if it drops inside the case.
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
Ok, but do you really need double low 2WD?  That's the only reason to have to pull the interlock pin in the rear case if you didn't when you built the dual setup.
R.DesJardin
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
There are times I want to go slower, and don't need 4wd.
OOPS
  • Male Posts: 2,561
Sure, when your screwing around and want to see if you can make it in 2wd!!
SqWADoosh
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
I never pulled mine and never felt a twinge of regret.  :dunno:
« Last Edit: Mar 23, 2017, 11:41:51 AM by SqWADoosh »
R.DesJardin
  • Male Posts: 489
So you're saying you don't "need" low, low 2wd.  :greengrin:
R.DesJardin
skid
  • Turtle Points: 144
  • Male Posts: 295
  • Member since Oct '04
Why have a twin stick if you don't remove the interlock pin?
I don't believe so, how would you move the shift rail far enough to allow the pin to come out?
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
SqWADoosh
  • Male Posts: 2,417
He said  "twang"  :rofl2:
Actually swiftkey said twang. Fixed for you, dilldozer.   :slap:
« Last Edit: Mar 23, 2017, 11:49:27 AM by SqWADoosh »
SqWADoosh
  • Male Posts: 2,417
Gosh Darn it no more boarding on my phone.  :smack:
« Last Edit: Mar 23, 2017, 03:25:55 PM by OOPS »
blackdiamond
  • Male Posts: 5,053
You did the triple stick setup primarily to relocate your shifters forward.  This makes sense.  I see no reason to install a twin stick without pulling the pin because it gains you nothing.
blackdiamond
  • Male Posts: 5,053
I could be wrong, but I though you could remove/slide the rail far enough and capture the pin with a magnet.
R.DesJardin
  • Male Posts: 489
Uh........................cuz it looks cool???? Like an Atlas. Yes I think I read somewhere you can remove the pill with the cases installed. Some double case install instructions from someone.
Triple Sticks are cool.  :yesnod:
R.DesJardin
OOPS
  • Male Posts: 2,561
No, you do not need it, but it's fun to have!!
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
He said  :haha:"switkey"
Is it possible to double like something?
I am 1/5th of Perfect Fit
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
I guess pulling the T cases will be the right thing to do so next week they'll be dropped but, this weekend I'm going wheeling and using the three location shifters that like to bash my fingers because I never had them bent to interference free positions.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Be prepared to drop transfer..........
But try without dropping first.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,238
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
TWANG
twaNG
noun
1.  a strong ringing sound such as that made by the plucked string of a musical instrument or a released bowstring.
TWINGE
twinj
noun
1.  a sudden, sharp localized pain.  "he felt a twinge in his knee"
synonyms:   pain, spasm, ache, throb; More
« Last Edit: Mar 24, 2017, 03:33:31 AM by Gnarly4X »
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
You know what they look like if you've been around here a while, I wanted Marlin sticks but, these are what I can get now.
The cases are almost out, just letting them drain overnight.
Everything but, a few bolts has been removed, unplugged, unbolted and unscrewed but, we are having a crazy So Cal "Wind Event" that isn't the Santa Ana winds but, is just as powerful even as cold as they are coming from the NW.
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
The simple answer to my question was, no.
It can't be done without dropping and separating the t case from the crawl box, T case has to come off so the shift rail can slide out so a magnet can remove the interlock pin.
I am about to put the crawl box back on the T case but, it is food time.
R.DesJardin
  • Male Posts: 489
So what you're saying is you feel the need to have 2wd Low, low.   :greengrin:
............................................................I am about to put the crawl box back on the T case but, it is food time.
R.DesJardin
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
For slow towing a VERY heavy trailer.............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
What I was saying was, I was hungry and putting the T cases back together had to wait until after lunch.
2wd low low? No, I need 4wd low low to go oh so slow, kind of like a turtle or tortious.
I need help getting this contraption back up and mated to the transmission, I only have one good hand thanks to a fonewhale.
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
All done, truck drives great and all 4 shifters do their intended jobs.
Last post Apr 27, 2004, 06:06:31 PM
by yotaboy79
Last post Mar 14, 2006, 11:59:27 AM
by Rocksurfer
Last post Jan 07, 2009, 05:58:16 PM
by 4RunnerChevy
Last post May 05, 2010, 08:40:10 AM
by Dmclat
Last post Dec 09, 2011, 06:02:56 AM
by crawlerbubba
