where can I find a 4bt Cummins?
Started by UNBREAKABLE, April 06, 2005, 07:53:21 AM
UNBREAKABLE
I am thinking 'bout running a 4bt. where can I find one? what did they come in?
That's how I roll
fritz
i'd love one too. hard to find. forklifts and tractor equipment?  there are many toyota diesel bolt up options if you get frusterated finding a cummins
Jack8542
Skid steers have four cylinder diesel engines in them.  I have heard of many Heeps using them but never a Toyota.  Im not sure if its a   :love:  cummins :love: though. It'd be sick to have a cummins in a Toyota, good luck.   :turtle:  :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
freds40
If you can find a yard that gets in the old Frito-Lay delivery trucks, they used to run them. Don't forget that these are not a light motor either, right around 700lbs. IIRC, a couple hundred pounds heavier than even a small block.
"between projects"
Willy Mammoth
Search for specs on the 4bt first. I think they are around 800 lbs. That is way to heavy. Also I think they are a little big. Look for the Toyota diesel, you will also need the bellhousing to match. Or even a Nissan SD22 / SD25. You can use a bellhousing from a ScoutII with a SD33 and adapt it to fit your trans.
Look here http://car-part.com/index.htm
SD22 1981-1984 Nissan pickup
Scout bellhousing 1980+/- with SD33
scheid6996
i saw a hudge orange jeep, well it was jus a jeep body, but this thing was sitten on 54 inch tires, rockwells  and a 4cyl detroit diesel, TURBO  holy :pokinit: this thing sounded bad ass,  MIKE D got stuck and this guy pulled him out, sop when u guys talk 2 mike D on here give him :pokinit: for letten a JEEP pull him out
Its a redneck thing
"Nobody Loves Me"
UNBREAKABLE
That's how I roll
Willy Mammoth
Just did a quick search http://www.usdieselengines.com/used_diesel_engines.htm
Keep searching around the net you are bound to find somthing
UNBREAKABLE
That's how I roll
yea and you'll have a engine heavier than a late 70's 454 or 460
Willy Mammoth
UNBREAKABLE
That's how I roll
fritz
you can get imported toyota turbo diesels that will bolt up from l.a. or s.f. for 1200, search on www.toyotadieselmadness.com for imported engines or somthing like that.
Willy Mammoth
#13
Quote from: RockwelledToyota on April 09, 2005, 06:25:14 AM
Where did you get it?
http://www.car-parts.com
Nissan / Datsun
1983
diesel
http://www.mhdfl.com/Videos/Engine%20Running%2002.wmv
http://www.mhdfl.com/Videos/exhaust%20test.wmv
Make sure any thing you get is complete fan to flywheel inc starter and alt. or you will be waisting lots of time searching for the other stuff.  Most will be SD22, but there are a few SD25 out there.
Toyota has 2L , 2LT , 3L Try to find one with manual injection pump, not electronic. Note that Toyota uses a timing belt that if breaks will bend all your valves. Nissan uses a chain and with the Nissan you can use a Scout II bellhousing from one that has a SD33 6 cyl. Then you should be able to use any trans you want and it is a light engine compaided to the 4bt.
TOYJOETA
What is the power like on the nissan SD22 compared to a 22re?  and will the scout bell housing work on a R-151?
Thanks
Joe
Willy Mammoth
Toyota 2LT on eBay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33615&item=7966545738&rd=1
I am guessing the SD22 has around 60 hp at 3000 rpm. The torq will be higher than a gas engine at a lower rpm.
I don't know if the R-151 can be made to fit the scout bell housing? The scout used a Amercian made trans with the SD33 6 cyl Nissan diesel. The SD22 4 cyl and SD33 6 cyl are the same engine family so the bellhousings should enterchange.
Duffil
Cummins' Power!!! 4cyl Cummins engines are common in ag pumps, and IIRC will bolt to a TH350, if you don't mind driving a sleeper!!
UNBREAKABLE
Yeah, they have a chevy bellhousing bolt pattern. I don't mind building one up for some sick torque! They came out in the Frito Lay trucks also
That's how I roll
