Marlin Spring Hanger on 85 frame
Started by Skim, April 05, 2005, 08:32:00 PM
Skim
Need pics of the Marlin Hanger Kit mounted on an 85 front end. Seen plenty of the IFS front ends set-up. But nned to get an idea of what you guys are doing about the front stock hanger on an 85 frame?
Thanks-
85 Hilux Long Bed - For Sale
oddball
Cut as much of the spring mounts off as possible.  If there is a gap in the middle put a piece of plate to fill the gap and weld it in.  I had to put a 1/8 inch plate on mine.  I made my own crossmember, but it should be pretty close.
TrackVino
Call Dean at Marlins, he just did this to his 85
Skim
So correct me if I'm wrong, but wouldn't I just weld it on the same way as an IFS frame? But I would have top part of the original sprin hangers visable. The IFS frame makes the front all smooth surface to weld to. Is the 85 frame not even? why would I need to wld in a added plate Hyena ?
Thanks man
oddball
Here is Roger Browns 85 4Runner, 4crawler.com Thats what I meant by the same, doesnt matter if its IFS or factory SA, drop hanger mounts the same. You could check out White Trashes design at $300 in the project research section. Youll see lots of diferent designs but they all mount under the crossmember
her is mine.  you can see the gaps.  i used 1/8 inch plate to fill the gap.  You can cut all of the old spring hanger off.  There is about 1/8 of it that will stay becasue the frame tubes go into it like that.
scheid6996
i had to cut out my front cross member, and buils a new one, its not 1/4 wall solid, no weight saving wholes like the toy ones
Its a redneck thing
"Nobody Loves Me"
