Altenator problems!
Started by whiteman, April 05, 2005, 03:55:06 PM
whiteman
The other night I was out wheeling in the snow and i was trying a climb up a bank when I heard this loud bang. I am almost certain that it was a rock, but at the same instant I heard this bang, my battery light came on as well as my parking brake light.  It does not hold a charge any longer so I need a new altenator or regulator.  But I cant figure out why my parking light came on.   What are some good ideas for a new altenator, do I have to use toyota specific?  ???   I know that my regulator is located in the altenator itself but could I  buy a chevy regulator and altenator with a one wire conection that puts out more power, rather than going back to toy stock?   Thanks for the advice :biggthumpup:
stomper
Mine did the same thing the other week. I Pirced a new alt for $79 Then looking through the hanyes manual I saw the brushed could be changed. I took the brushes out and sure enought one was worn all the way down. I got the new brushes from Advance auto parts they had them in stock $10 is all they cost. There real easy to change. I pulled the alt I didnt drain the rad. I removed the bolt holding the metal tube for the lower rad hose and could get it out with some wiggling and pulling. I then pulled the regulator cover off the back of the alt. Next right in the center the re is a bolck with 2 screws holding it in. This is the brushes it has a rubber cover theat will come off with it. I heated th esolder on the old brushes till I could pull them out and soldered the new ones back in and put it all back together. Lights went out and it charges.
Mine didnt go boom but I drove it to the store and it was fine came out and it was bad. Go figure. Save the cash and check the brushes either way your going to pull the alt.
Duffil
charge and brake always come on together...
86 4runner
if you do get a new toyota altenator make sure you get it from toyota, all the other ones are :pokinit:
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
Huhwhye
Quote from: 86 4runner on April 05, 2005, 10:49:44 PM
I 2nd that, but a Toyota alternator cost $350 at the dealers near me.
'04 Taco DC 4x4
86 4runner
refurbished ones from toyota work just fine and they are about$170
whiteman
Thanks guy's I'll pull my alt. tonight and see what the brushes look like.   :thumbs:
whiteman
Gal Blasted!!!  It still dont work :mad:  wht the crap man.  Can I just convert it to a chevy 140amp alt.  :-\\
