SR5 Guage Cluster Install...Need Help!
Started by YOguyDa, April 05, 2005, 03:26:04 PM
YOguyDa
I've got an '81 Pickup, and i just bought an SR5 cluster from a '79. Not sure what to expect as far as ease of install. What do i need to do to hook up the Tach? Anyone who has done this, please let me know. Thanks.
'86 2wd now...
Ferg
Just plug it in and go!  It's all the same.
notajeep
kyle_22r
no, '79 and '80 models with upscale trim were called the "sport"(as far as 4x4s go, 2wds were available as SR5 because they had an available 5 speed).  this got you the tach in your main cluster, and the auxillary oil presure and voltmeter gauges in a nifty console add-on.
don't quote me, but i think '79 and 80 had a different style plug from '81, and most definitely different from '82-83 :shudder:
YOguyDa
Hmmm, I bought the cluster off a guy on Pirate, who was parting out his '79....Basically its has the same thing as my '81 + the tach... I read somewhere that 79-81 had round plugs and 82-83 had square...I seem to be hearing a lot of different things, so i guess i should just dig in and see how it goes. Anyone know how to hook up the tach at least? I know you have to run a wire from the coil...but on the back of the cluster it just looks like a circuit panel with holes in it...lol. I guess i will see.
'86 2wd now...
Skinny_Pedal
79-81 are the same from what i have done. attempted to put a 82-83 cluster in an 81...wasn't happening. as far as 79 sr5's go. i have seen 79 20r 4x4's with the full instrmentation.
Im an OG
gnob
my 79 is a tach dash rig.
but there was not an SR5 tag, i guess that deal above explains why huh.
hold this. . .
YOguyDa
Thanks for the info guys. Im gonna go at it tomorrow in the day light....Ill let you guys know how it goes..
'86 2wd now...
Hey YOguyDa,
I know its a location on the circular plug but I do not remember which one. Also my FSM for a '80 does not show which slot its at, it just shows the IG+ wire going to the tach.
I know its a black wire and I also remember that there are 3 black wires that all look the same..
But shouldn't your '79 harness already have a wire routed from your coil up to the cluster plug? Assuming Toyota was at least already planning on it, maybe in prototype stages, then all optional wires should already be routed.
I know Marlin put in a SR5 cluster in his '80 and I believe it was just a plug-n-go affair
gonzo
KYOTA
Dont know about 79 but when I installed SR5 gauges into my 83 I had to re-pin the wiring in the plugs and run a tach wire to the back of the gauges. Heres the pin diagram for the swap in the tech-section
http://board.marlincrawler.com/index.php?topic=2973.0
Good link but its for the ugly 1st gen clusters = (82-83)
YOguyDa
Well, the whole process was plug n play...But the tach doesnt work. It will jump up to whatever rpm i rev it to, and then fall back down and stay there. So, it seems to be reading extreme fluctuation in rpm for a second and then sitting at 0 for the rest of the time. Any ideas?
'86 2wd now...
