So here is what I have 1988 std cab, 5 spd dual case 10deg. front range mount. Just rebuild and balanced rear shaft.
Problem...... 50mph plus 4th and 5th gear if I let off the throttle (not under a positive load) I get the noise.
Or just put it neutral and coast, I get it. If I down shift to slow down Iam okay.
Goes into gear fine, just build the truck, and cases. Also clean fluid 80/90 in everything..... and no metal on magnets.
I read somewhere on here that a double joint drive shaft may solve this issu? Ideas?
![Hammer :hammer:](https://board.marlincrawler.com/Smileys/marlin/hammer.gif)
