0 Members and 8 Guests are viewing this topic.
They should bolt right up. Post the pics you got. Maybe the slides are slightly bent?
Does the bucket seat inner mount line up with the split bench seat belt mount? If so, use that one, then mount the seat belt inner mount to the transmission tunnel, there should be a factory threaded mount under the carpet.
My seats. Sent from my Nexus 6 using Tapatalk
Had my buddy do it for around 150. If you take it to a shop they will quote ~300. Sent from my Nexus 6 using Tapatalk
You don't gotta get too fancy with it, my truck only has like 2 bolts per seat
This is the view from the bottom of the bracket.
Some guys have made and bent little metal brackets to make seats line up. Might be able to swap out mounts.
Looks good. Do you know the year the seats came from? Cause i didn't have to modify anything. Then again it was going into an 87 PU not a new 90's style.It does look like you are on track there. If you have to drill the bed, make sure to use some silicon and seal it so it doesn't leak into the cab. Also why not fab up a little bracket to hit the one missing bolt hole and leave your seats in one piece?
I sadly don't own any mechanical or electric metal working tools. Buckets are from a 90 the original is a 94. I am going to try and find a good place to go that has a welder and metal tools they will let me use to make a bracket. I am probably just going to cut the foot and weld a piece on then re weld the bolt piece so it is longer.
Any decent MIG welder will do. It won't take much for the seat bracket material. Any 110 MIG would do that. Try to borrow one and see what you like.
Started by KYOTA General 4WD Discussion
Started by BMFN_TOY Parts For Sale
Started by Brandon Parts For Sale
Started by burl4x4 Parts For Sale
Started by B-R-I-A-N Parts Wanted
