allpro lift on 82
Started by TW82, June 03, 2016, 11:51:28 AM
TW82
Anyone have any problems with allpro instructions on their extreme 4"lift. I'm having trouble with the front spring hanger location
mudmaster
I didn't have any issues. It needs to be moved 1" forward of the cross member. This pic isn't very good. AP has a pic on their site.
Time to go wheelin!
TW82
That's what I did then checked the shackle angle and it was like 19 degrees I think when it settles the angle will even be more the instructions say that 15 degrees is the target after the springs break in should I cut the hanger off and move it forward thanks for the help
mudmaster
Did you tighten the bolts once on the ground?
Time to go wheelin!
TW82
No when it was on stands ,should I ? How tight are the shackle bolts supposed to be
mudmaster
They should be tightened with the vehicle weight on the ground. FSM should have the torque.
Time to go wheelin!
