Running lights
Started by PAYN80PickUp, February 19, 2016, 01:26:27 PM
PAYN80PickUp
I have a 1980 pick up an after doing dual cases I no longer have running lights in the rear but all other lights work has anyone else had this problem replaced lights an not the issue
did you disconnect something? or snip a wire?
Sounds weird that you did dual cases and now your lights don't work.....
redneckcustoms13
First check your fuses, then ground for the tail harness. If no luck test for power at the plug. Make your way forward till you see the problem.
01 double cab hunting truck
06 tacoma street truck
