Author Topic: alternator choices, what are you using?  (Read 3825 times)
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26840
  • Male Posts: 3,508
  • Member since Dec '10
« on: Feb 02, 2016, 08:10:57 AM »
well my alternator went out  :thumbdown: (been a week, driving me crazy as this is my DD).  I'm running dual batteries, winch, hid aux lights, rock lights, cb, 30 psi on demand pump for on board shower, and all the little gadgets, My last one was a 150 amp modified Toyota unit, looking at options: another high ouput?, chevy cs144?,i have been reading alot, wanna get some suggestions, and why?  any input would be appreciated
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Re: alternator choices, what are you using?
« Reply #1 on: Feb 02, 2016, 07:46:24 PM »
I can't remember, are you ring 3rz or 22r? On my 80 with a 22r I'm running a $25 gm 1 wire that I had a local starter shop mess with to get about 200 amp from. Really nice not to worry with those pesky regulators and it not bog the engine down to run an electric compressor.
01 double cab hunting truck
06 tacoma street truck
Win243
  • Turtle Points: 132
  • Male Posts: 39
  • Member since Dec '13
« Reply #2 on: Feb 03, 2016, 02:04:12 PM »
I put this one on my 22re 1988 4Runner after I realized how difficult it would be to fit the larger GM type.  It works well.  I still had to do a little grinding to make it fit, but it was doable.
http://www.summitracing.com/parts/PWM-47294
My only complaint is that you have to rev it up for awhile to get it to start charging.  It doesnt start charging at idle right after you start the engine.  Once its charging, it WILL charge at idle.
 :beer:
1985 Hilux
1987 AW11
OVRAROK [OP]
  • Male Posts: 3,508
« Reply #3 on: Feb 03, 2016, 02:24:26 PM »
 :beer:
yeah, this is my problem I'm finding, ive called a lot of company asking when it kicks on, people telling me 1800rpm, ive found a place about 1.5 hours away, made an appointment, he told me he will give me quote after testing unit, we'll see
Win243
  • Male Posts: 39
« Reply #4 on: Feb 03, 2016, 02:41:49 PM »
I have found that once it is charging, it will charge even at idle.  But it takes awhile to get it there.  Revving it up to 1800 a few times isn't enough, it has to be driven a bit before it does its thing.  That being said, I am happy enough with it that I will probably buy another one for my new 1985 project if it ever goes out.
1985 Hilux
1987 AW11
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #5 on: Feb 03, 2016, 02:53:11 PM »
If the housings are the same as the MKIII Supra, this might be worth looking into.
http://www.suprastore.com/hiou100ampal.html.
Might also see what they can do with the stock 22r one.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #6 on: Feb 04, 2016, 08:00:15 AM »
Glen runs two alternators on his 79.  One is the main one, and the other is switched from inside the cab.
dmczeke
  • Turtle Points: 212
  • Male Posts: 53
  • Member since Dec '09
  • 3MTA3
« Reply #7 on: Feb 04, 2016, 02:53:04 PM »
My rig is a 1985 22re 4runner, no ac compressor. I run a junkyard CS144 from a Cadillac with the TG GM conversion mount. It's a tight fit but can be done. Simple wiring, good amps at 2000rpm.Works great for me
OOPS
  • Online The 2.5K Group
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #8 on: Feb 04, 2016, 03:42:16 PM »
Here is a write up I did on putting a PowerMaster Alt, on my 3.0. Embedded in the write up is a link to putting one an a 22r. Pictures are gone in my write, I am going to see if I can fins them to replace them.
http://www.pirate4x4.com/forum/toyota-truck-4runner/458156-hi-amp-alternator-3-0-v-6-a.html
Mario
  • Turtle Points: 215
  • Male Posts: 66
  • Member since Mar '08
    • Buy me a drink
« Reply #9 on: Nov 22, 2016, 08:47:53 PM »
Summit Racing sells one wire Chevy alternators and Trail-Gear sells the bolt on bracket. That's what I am running on my 84, efi toyota.
1984 Toyota Pickup, EFI with duel cases, 5.29's in the diffs, 4" Trailer HD leafs in the front, Chevy's with 3" blocks and a track bar/pan hard bar in the rear with full exo cage.
79chevy39.5s
  • Turtle Points: 197
  • Member since Dec '16
« Reply #10 on: Jan 01, 2017, 11:25:07 AM »
I run a 88 Cressida/supra 80 amp. Fits the same as an efi 22re alt and wires same too
Last post Oct 14, 2005, 08:24:28 PM
by kyle_22r
Last post Nov 01, 2007, 08:09:55 AM
by Steve97TJ
Last post Oct 23, 2020, 02:15:03 AM
by bordain
Last post Oct 05, 2010, 05:13:48 AM
by 66cobra
Last post Jul 05, 2012, 12:00:11 AM
by 80hilux4x4
