0 Members and 8 Guests are viewing this topic.
Hello tx_shooter,And to land!! That's awesome that you got one of our t/cases, congratulations!! You are gonna love it! It is possible to swap out the input gear however the input is part of the low range reduction system and as a result you can only swap out inputs from the same ratios. In other words, your current 21-spline input is from the stock 2.28:1 reduction gear set while the 23-spline input you just picked up is from our 4.70:1 reduction gear set. They cannot be interchanged.To make matters a little bit worse, we make two different 4.70:1 gear kits: One from 8600-series material (our XD gears) and another from 4300-series material (our Competition gears). Whenever you have two gears meshing with each other, it is absolutely critical that they both have the same material properties as well as annealing process so that they have highly similar hardness, durability, and tensile and yield strengths. Otherwise the gear that is harder and more durable will rapidly wear into and destroy the gear its meshing with.So to answer your question: Yes, absolutely this is possible. But we need to find out what gear kit you have ... if it is our Competition gear kit or our XtremeDuty gear kit. Do you know anything about the history of the t/case? Do you know how old it is? Does it have our name with a serial number stamped on the front housing that says "Marlin Crawler 4.70:1 123" where 123 would be the serial number?At any rate you are going to have to open it up to swap out the input. Take a look at our 4.70:1 Installer (link) to get an idea of how it all comes apart (if you haven't already done this before). Once you've got the gears exposed, replying to this thread with a couple pictures wouldn't be a bad idea either Regards,BigMike
also if this is for a rear case in a double case setup you might want to look at getting the 23 spline coupler and retaining the 23 spline input and it would be stronger.
To rephrase the original question - can I move the new gear from the 23 spline shaft to the 21 spline shaft to keep the gear ratio correct? Is this possible or are the gear and shaft all one solid machined piece?
Bump for an answer for my old T-Case
This.Trying to put 4.7s in my transfer case. The donor case that had the 4.7s was a forward shift with a 23 spline input shaft. I tore down the case; harvested the needed parts and am trying to put them in my case. The problem is that the smaller input gear is on the 23 spline input shaft; I need it on my 21 spline input shaft. I have looked it over pretty closely and do not see how/where it would come apart. Google-fu came up pretty short also. So - is it going to have to be a new shaft or is there a way to move the smaller gear from the 23 spline shaft to the 21 spline shaft?
Started by rayl82 Parts Wanted
Started by DD85runner For Trade or Barter!
Started by DD85runner General 4WD Discussion
Started by DD85runner Parts Wanted
Started by hamish_18 Toyota Pickup/4Runner Tech 1979-95
