Author Topic: 37 MTR repair  (Read 3921 times)
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
37 MTR repair
« on: Dec 14, 2012, 02:27:16 PM »
So i picked up a set of 37 by 12. 50 on 15 and one tire had this happen to it wondering if I can put some rubber cement in it or what
all this only on one tire  one the same side
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Re: 37 MTR repair
« Reply #1 on: Dec 14, 2012, 02:28:43 PM »
  they all held air
« Last Edit: Dec 25, 2012, 05:56:27 PM by tgmaul88 »
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
37 MTR repair
« Reply #2 on: Dec 14, 2012, 02:54:05 PM »
Get it vulcanized.
You'll never take me alive
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Re: 37 MTR repair
« Reply #3 on: Dec 14, 2012, 06:02:49 PM »
and den
Slolyfe
  • Male Posts: 2,048
  • Heyo
37 MTR repair
« Reply #4 on: Dec 14, 2012, 06:26:58 PM »
Get it volcanized.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: 37 MTR repair
« Reply #5 on: Dec 14, 2012, 06:56:21 PM »
and den
getting it vulcanized means that it gets heated up to the point that the rubber melts back together again.... like when it was being made
there are some shops that do this
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Re: 37 MTR repair
« Reply #6 on: Dec 14, 2012, 06:59:24 PM »
thankyou ill call around on monday theres a 18 wheeler - tractor tire place local
  • Male Posts: 8,707
Re: 37 MTR repair
« Reply #7 on: Dec 14, 2012, 07:08:21 PM »
i only recommend this because the bead and inner plies of the tire are fine, if they were compromised/torn/cut in any way, it would be unsafe to use
4low4runner
  • Male Posts: 38
  • Member since Jun '11
  • Let it idle and crawl...
Re: 37 MTR repair
« Reply #8 on: Dec 30, 2012, 12:14:59 AM »
One of my tire was torn on the sidewall like your I put on some bead sealer once it dry up it turns into rubber work great
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: 37 MTR repair
« Reply #9 on: Dec 30, 2012, 10:28:27 PM »
Alot of places won't touch that.  So, find a hole in the wall place that don't ask questions.  And tell them it's strictly for off-road use only.  If you tell them that it will see hwy use, they might touch it.  I personally would get it vulcanized, and then mount them up on some bead locks, and run the piss out of them.  Or if you can find a used one to match the other three, and use that one as a spare.
dalton1993
  • Turtle Points: -2
  • Member since Apr '14
Re: 37 MTR repair
« Reply #10 on: May 11, 2014, 07:15:53 PM »
How does vilcanizing hold up?
Slolyfe
  • Male Posts: 2,048
  • Heyo
Re: 37 MTR repair
« Reply #11 on: May 20, 2014, 11:16:51 PM »
Mine have held up great. Many trips on them and stil look like new.
Last post Oct 07, 2005, 11:06:51 PM
by Gearhead Wiki
Last post Mar 26, 2007, 02:27:31 PM
by Yota Tony
Last post Jun 25, 2014, 07:14:23 PM
by urbandork
Last post May 01, 2015, 09:38:58 AM
by 19psi
Last post Aug 20, 2017, 07:19:10 PM
by cporche
