you can fill it from either one, it should hold 3 quarts. even if you only pull the rear drain it will still drain the front box also at the same time, its all the same.
what weight oil or gear oil should i use? so it doesn't matter which shifter i fill, but i need to pull of the drain plug just to make sure its full? kinda got lost, this is a noobie question
Started by toymachine General 4WD Discussion
Started by gotrocks Parts Wanted
Started by IEATRKS84 Newbie Questions
Started by Bob Williams Transfer Case/Drive Line
Started by sjelite Transfer Case/Drive Line
