"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
i would take the master back. they may given you the wrong part. i forget which master cylinder it is(4cyl, v6, ifs, solid, etc), but there is one that has a shorter throw than the others and it doesn't push far enough.
Have someone watch the slave cylinder while you pump the clutch to see if the slave is getting a full throw.
So i got it fixed it was the clutch pedal bracket that was broken so it wasnt depressing it was just the bracket flexing i pulled it out welded it back and it was all better who would have thought
Started by YOguyDa General 4WD Discussion
Started by 84_yota_4wd Toyota Pickup/4Runner Tech 1979-95
Started by COToy91 Toyota Pickup/4Runner Tech 1979-95
Started by gregers05 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by JD93TOY Toyota Pickup/4Runner Tech 1979-95
