255/85/16 33" will fit stock (if you have stock 16" rims). Take the mud flaps off and trim the plastic a little.
For a lift, run the 1.5" ball joint spacers (86-95 trucks/4runners) up front (SDORI, Toytec). Rear, either AAL or a 5.5"-6" shackle (stock is 4.5"). A standard "wide" shackle kit will fit, but you have to use extra spacers, as they aren't straight shackles, they are narrow on one end.
