Dual setup, rear case is a topshift 23 spline with Marlin's 4.7 (newer style). Some times the case is a PITA to get out of 2-high. Takes two hands and a bunch of force. Case has less then 75 miles on it. Did I do something wrong when I rebuilt it or is it normal on a fresh case? Thanks!
![Slap! :slap:](https://board.marlincrawler.com/Smileys/marlin/slap.gif)
DONT FORCE THE LEVER EVER
![Spank Butt :spankbutt:](https://board.marlincrawler.com/Smileys/marlin/spankbutt.gif)
if you havent already bent the shift fork you will, never force it.
dont drive on a hard surface in 4wd, this will cause things to get in a extreme bind and with enough traction you could blow the case apart
5 pounds of force is all you should ever need, if it needs more change direction till it does
