Author Topic: crawler case shifting issue  (Read 1203 times)
bkuknyo
  • Turtle Points: -1
  • Member since Feb '14
« on: Feb 22, 2014, 05:55:33 AM »
I have purchased a used rig and the front crawler box will only shift foward low and middle neutral. It also appears that the key stock was not welded due to the shifter being able to go left to right any ideas?
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: crawler case shifting issue
« Reply #1 on: Feb 22, 2014, 03:32:11 PM »
Without the key stock welded in, it's gonna be hard to diagnose much because the shift handle will flop around and fall in and out of its shift gate... I suggest removing the shift handle and possibly also the shift base and operate the shift fork with a medium sized flat head screw driver to be absolutely sure that it is unable to access high range.
The most common issue is that a Crawl Box cannot engage low range when the transfer case is in high range (due to an installation error of not modifying the transfer case's driver's side shift rail for use with a Crawl Box). But your case is the opposite which is strange indeed.
It's shift rail could be installed 180-degrees off, or it could have a rusted shift spring... Pop that shifter out and have a look inside to see what is going on.
Regards,
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
« Reply #2 on: Feb 22, 2014, 07:30:55 PM »
as big mike already stated the most common prob is the shift rail needs to cut down like a 1/2".
i installed my cases without doing this mod and the crawl box wouldnt go into high range. so pulled it pack out and clearanced the rail and boom it went into gear.
as for the other thing follow bigmikes advice and pull that shifter and have a peek.
bkuknyo [OP]
  • Turtle Points: -1
« Reply #3 on: Feb 23, 2014, 04:31:45 AM »
Makes sense, ill take a look
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Feb 23, 2014, 08:25:02 PM »
...and :welcome:  to the board
Last post Mar 11, 2003, 01:29:47 PM
by mobil1syn
Last post Oct 24, 2005, 04:53:51 PM
by Jared
Last post May 31, 2007, 08:40:34 AM
by jbtaco2002
Last post Feb 26, 2009, 04:34:13 PM
by Bighoss22r
Last post May 10, 2014, 01:13:44 PM
by Toyonrocks
