axle bearings and carrier bearings are the same, so is it possible to swap the side gears from a 2wd carrier into a 4wd carrier, allowing use of the 2wd axle shafts? you'd end up with a 5lug 8inch rearend.
really? thatd be awsome!
ive got a 2wd rear axle off an 84 that uses a 4wd 4cyl carrier, it came with 3.05's and i put in a 4.10 3rd member, so there are some 2wds that are runnin a 8" ring gear, but most use the 7.5 ring gear, the same as in ifs front end, so gears and lockers are available for it, either way
balljoint spacer is for the front. see if u can find some old pics of my 2wd
Started by hacksaw Parts Wanted
Started by Dreadnought General 4WD Discussion
Started by KYOTA Toyota Pickup/4Runner Tech 1979-95
Started by cruiserfj45 Parts For Sale
Started by sandboxtoy Parts For Sale
