Yes, you gotta use the r151 bell housing. You will need 23 spline input in your tranfer case. Or get the turbo T-case with the tranny. If your gonna use a turbo clutch then you need the turbo flywheel also. But you can use your regular clutch with your stock flywheel for either tranny. and i believe those trannys would use the same crossmember and are both forward shift.
