Author Topic: leaf spring question with pictures  (Read 3243 times)
madmanweaver444
  • Turtle Points: 197
  • Member since Jan '08
« on: Apr 26, 2008, 10:36:01 AM »
a spring in my pack broke the second from the bottom is the one that broke just in front of the u bolts
what do i need to get to replace this, is it just a add a leaf or what
 here are the pics
here is the back side of broken spring
other side leaf spring
spring i got from pick a part its the wrong one though
The mountains are calling and I must go.
-John Muir
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re: leaf spring question with pictures
« Reply #1 on: Apr 26, 2008, 11:24:32 AM »
Looks like a short add-a leaf.  I'd be willing to bet its from pro-comp just for the fact that they make a shiat ton of those for everything.  Either pull them both out or grab a set of replacements.  If going with aftermarket replacements I'd suggest getting a pro-comp LONG add-a leaf.  Much better ride and they won't break. ;)
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Apr 26, 2008, 11:39:20 AM »
go to a junk yard  and buy  a set of  springs  from a 2wd  s10  or  2wd  f150   and  take a leaf  from those packs  and add in there  those short POS  add a leafs  are junk
you need  the long  bottom leaf  for  daily driving, hauling stuff,  it keeps the pack from going negative
btw  you should be able  to buy a  pair  of  s10  spring packs for $50
madmanweaver444 [OP]
« Reply #3 on: Apr 26, 2008, 03:41:54 PM »
http://www.4wheelparts.com/Add-A-Leaf-Kit.aspx?t_pt=5488&t_pl=3884&t_pn=SUP7000
with this be a good one to replace it with
can i still go wheeling with the broken one though or would i have a higher risk of breaking something else
-John Muir
« Reply #4 on: Apr 26, 2008, 05:22:18 PM »
a little pricey  but  yea  that would work
no  dont wheel it till you get it fixed,   driving should be ok as long as you dont  drop the clutch too hard
« Reply #5 on: Apr 26, 2008, 05:28:14 PM »
so the s10 or f150 springs would give it the same lift as the add a leaf right because i dont wanna loose any rear clearance
cuase i might go on half price day or something to pick a part
-John Muir
« Reply #6 on: Apr 26, 2008, 06:16:23 PM »
the  sweet part is,  the  f150  or  s10 2wd  springs  have LOTS of arc  and  are  thin  so you can actually use  2  leaves  in place of that 1  thick  leaf  and have a much better ride  with the same lift
i had s10 leaves in my old springs,  but  went with complete F150 packs this time
http://board.marlincrawler.com/index.php?topic=5628.msg566145#new
« Reply #7 on: Apr 26, 2008, 08:15:41 PM »
so i would use the main springs (2 of them)  from the s10 in place of my add a leaf
-John Muir
« Reply #8 on: Apr 27, 2008, 06:04:55 PM »
um NO  not  the  "main"  leaf,  take the s10 spring pack apart  and  choose  the leaves  that are  the shortest (still longer than the thick add a leaf)  and place them where the thick leaf was
84pickup
  • Male Posts: 335
  • Member since May '07
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
« Reply #9 on: Apr 27, 2008, 06:29:29 PM »
 i bought some lift springs at a junkyard. they were off of a 79 pickup they were only 180$.
lets not and say we did.
« Reply #10 on: Apr 27, 2008, 06:34:48 PM »
alright thanks alot
-John Muir
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #11 on: Apr 27, 2008, 11:26:39 PM »
:yikes:  $180 for junkyard springs!!  sorry to say, but you got hosed big time.  :yikes:
              -Ronald Reagan
« Reply #12 on: Apr 28, 2008, 09:59:58 AM »
you > :bumpinbutts:  < junkyard   :headshake:  yep  you got raped
did it include the front axle :dunno:
sabenson82
  • Male Posts: 70
  • Member since Mar '08
« Reply #13 on: Apr 28, 2008, 11:01:46 PM »
Shoot! :hammerhead: you got screwed! i paid less for brand new 44044's...
Build it, Break it, Build it again...STRONGER
84pickup
  • Male Posts: 335
« Reply #14 on: Apr 30, 2008, 02:54:02 PM »
it was for 4 good springs that gave me 3 inches of lift and they had daystar bushings already in them. no the axle didn't come with them. someone already took it. even then i don't need one because i've already got one you see and it'sa very nice. i thought it was a good deal considering i could buy one set of brand new springs for that much. i'm pretty happy with them, they ride great and they gave me a good lift. although i haven't had a chance to try them out on the trail.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #15 on: Apr 30, 2008, 03:14:21 PM »
:thumbs: well, if you're happy with it, thats all that really matters :yesnod:
              -Ronald Reagan
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #16 on: Apr 30, 2008, 07:22:34 PM »
Oh now you are using my lines eh? haha :gap:
« Reply #17 on: May 03, 2008, 08:02:56 PM »
got the springs on they were to long so i had to get out the grinder and cut them down
thanks
-John Muir
Last post Aug 09, 2004, 01:36:33 PM
by Bazzi
Last post Jun 16, 2006, 11:39:45 PM
by 88toyta35s
Last post Nov 05, 2009, 06:10:59 AM
by diggtbks
Last post Jan 23, 2012, 08:07:38 AM
by CODY C
Last post Apr 26, 2016, 06:17:51 PM
by dustingro
