Author Topic: 20r idle 2 high  (Read 2443 times)
buckeye1437
  • Turtle Points: -1
  • Member since Nov '07
20r idle 2 high
« on: Nov 09, 2007, 02:59:32 PM »
my 1979 20r started idle to high play with but it wont idle right just looking for some help or info thank you
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
Re: 20r idle 2 high
« Reply #1 on: Nov 09, 2007, 04:59:16 PM »
try the idle adjustment screw.... timing.... or maybe the choke is stuck????
buckeye1437 [OP]
  • Turtle Points: -1
Re: 20r idle 2 high
« Reply #2 on: Nov 09, 2007, 06:06:29 PM »
thank you for the help but i tried  that and it still idles at 1500 rpm have not check timing yet will do that later thank you
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
Re: 20r idle 2 high
« Reply #3 on: Nov 09, 2007, 06:14:14 PM »
You may have a vacuum leak somewhere. check for that. I would disconnect the brake booster line and plug it, first. Then check all of your vacuum lines. Then, check all of the egr connections, from exhaust to intake. It sounds like it is getting air from somewhere besides the carb (can't adjust down).
SAVE TELLICO post 491
buckeye1437 [OP]
  • Turtle Points: -1
Re: 20r idle 2 high
« Reply #4 on: Nov 10, 2007, 02:24:53 PM »
i will check that thank you
buckeye1437 [OP]
  • Turtle Points: -1
Re: 20r idle 2 high
« Reply #5 on: Nov 12, 2007, 03:43:06 PM »
every thing is good
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
Re: 20r idle 2 high
« Reply #6 on: Nov 12, 2007, 05:46:56 PM »
So... what was it?
buckeye1437 [OP]
  • Turtle Points: -1
Re: 20r idle 2 high
« Reply #7 on: Nov 14, 2007, 04:47:43 PM »
i meant there was no leaks i still have the problem
Last post Jan 20, 2008, 02:37:51 PM
by emsvitil
High Idle
Last post Jan 24, 2008, 05:24:24 PM
by kneedownnate
Last post Jan 13, 2009, 05:57:39 PM
by emsvitil
Last post Mar 07, 2009, 12:26:39 PM
by RABIDYOTA
Last post Sep 23, 2009, 08:20:05 AM
by Makohon
