Author Topic: high idle with screw all the way in?  (Read 2696 times)
OHToyguy
  • Male Posts: 9
  • Member since Nov '08
« on: Jan 11, 2009, 12:41:57 PM »
My "86 22re idle's @ 1200 RPM, with the idle screw turned all the way in. i ran the screw way out, then all the way back in, but its still soo high. i'm not sure what effect this would have on setting my timing, but i obvioulsy cannot set it the way my manual says to. besides the fact that my truck idleing soo high is annoying and can't be good.  :help:
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
Re: high idle with screw all the way in?
« Reply #1 on: Jan 11, 2009, 01:29:03 PM »
its proble a vacume line. trace all of them. my 3.0 used to idle at ATLEAST 2000 rpm's for a while. it sucks
UA 342
STEAMFITTERS
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
« Reply #2 on: Jan 11, 2009, 02:18:36 PM »
And include checking the egr system for vacuum leaks (the part that actually routes the exhaust gasses from the rear of the head to the rear of the intake). As can be found in many other threads, this is a common problem.
SAVE TELLICO post 491
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #3 on: Jan 11, 2009, 02:58:53 PM »
Sounds like the air valve is broken..............
(under the throttle valve; 2 air hoses and 2 coolant hoses attached to it, and a 2 wire electrical connector)
Has an internal air valve controlled by an bimetallic strip;   As the engine warms up, it closes the valve.     If the electrical connection goes bad (can be internal or external) it pretty much quits working.
It's very pricey.   You can tweak it close, or plug up the hoses, but you need to raise your warm rpm (about 1000) so that engine will still run when cold..........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OHToyguy [OP]
  • Male Posts: 9
« Reply #4 on: Jan 13, 2009, 05:47:03 PM »
i misted every vac line w/ carb cleaner, wasn't sure if that would do it, so tried either, didn't change my results: nothing. air valve huh? i'm kinda mechanically retarded so i don't know what that is, but your discription helps emsvitil. thanks, i'll hit back and let you guys know if that worked. thanks!
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #5 on: Jan 13, 2009, 05:55:17 PM »
http://www.autoshop101.com/forms/h60.pdf
page 4, sort of looks like the diagram too........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Last post Jun 04, 2005, 11:08:04 PM
by crawlerdan
Last post Nov 14, 2007, 04:47:43 PM
by buckeye1437
High Idle
Last post Jan 24, 2008, 05:24:24 PM
by kneedownnate
Last post Oct 10, 2008, 07:46:09 PM
by AaronB
Last post Mar 07, 2009, 12:26:39 PM
by RABIDYOTA
