Author Topic: 22r engine removal write up  (Read 23450 times)
toeyota
  • Member since Jun '07
Re: 22r engine removal write up
« Reply #30 on: Aug 01, 2007, 03:55:06 PM »
Yeaa i bet it would be a pain to pull it all together. My Hoist is hanging about 10-12 feet above the floor, so it would work but im not even going to try. Im about to go out right now and mess with it again, should have it seperated today, thanks again for all the help.
toeyota [OP]
« Reply #31 on: Aug 01, 2007, 07:41:36 PM »
Got the motor pulled out, went good.  One question about the motor mounts, its hard to explain but when i took the nut off of them and lifted the motor out  the metal piece with the stud in it came out with the motor, its probably normal. ILl take some pics tommorow, i just got to thinking about it and if all of that comes off, i dont see how it holds the motor in after its installed back.
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #32 on: Aug 01, 2007, 08:16:55 PM »
That don't sound normal to me. Did you remove the two bolts that hold the bottom of the mounts to the frame? If not those mounts are toast, and need replaced.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #33 on: Aug 01, 2007, 08:57:14 PM »
I have used a really long extention with wobbly and I've used a flex head ratchet (for getting to the top two bell housing bolts), both with good results.
I like to Drive!
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #34 on: Aug 02, 2007, 01:21:32 PM »
man i lucked out on have my sisters same 87 as mine to reference to.
THANK GOD!
and i left the trans in truck when i took mine out.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #35 on: Aug 02, 2007, 01:22:24 PM »
the two top bellhousing bolts ARE A PAIN!!!!!!!
Ewong
  • I love Marlin Crawler!
« Reply #36 on: Aug 05, 2007, 11:36:17 AM »
Remove the cross member
I take off the drive shafts at the flanges.
IMHO it just makes things easier in the long run
support the trans on a tranny jack
use a 1/2 Loooong (20"?) extension bar
Do NOT USE a 3/8 extension bar - it winds up like a torsion bar (which it is)
Remove the shifter console, the rubber shifter boot and the shifters
Stuff a rag in there so ya dont drop a screw in the tranny
use the extension and a helper below to GUIDE the socket onto the bolt (17mm?)
You are going to use the ratchet INSIDE the cab (if the seats are out this is even easier)
Use a 1/2 drive LONG handeled ratchet to bust em loose...
The ratchet is inside the cab and will be braced against the stick shift tower when yer leaning on the handle..
yeah yeah - still IFS...
Last post Apr 08, 2005, 01:00:39 PM
by BamaToy
Last post Feb 26, 2007, 09:34:10 PM
by Wermz84
Last post Apr 27, 2008, 08:33:24 PM
by Cheesemaker
Last post Jul 09, 2010, 09:53:59 AM
by kneedownnate
Last post Aug 29, 2010, 05:29:49 PM
by pumkin toy
