Author Topic: 89 x-tra cab on 81 single cab frame??  (Read 1513 times)
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
« on: Nov 12, 2007, 08:31:55 AM »
i just picked up my new cab to replace my 1st gen cab with (cause mine is demolished) i got an 89 x-tra cab to stick on my 81 frame and i was curious if anyone knows much about the cab mounts... obviously this cab is a lil longer than mine and i have not got to do any measuring yet but it appears that the front mounts up at the grille should fit right up and possibly the mounts rite by your feet inside the cab should work and then i will have to move my rear cab mounts back.... does anyone know if indeed these front mounts will fit up to my 1st gen frame? i am also kinda worried about the back of the cab and the frame curving up to clear the rear axle but hopefully i wont have to notch the cab out to clear the frame rails.... please give me any input or info about this you may have.... thanks
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 89 x-tra cab on 81 single cab frame??
« Reply #1 on: Nov 12, 2007, 10:22:57 AM »
befor you notch the cab i would try a 2 inch body lift  or  just  cut  the mounts off the frame  move them  UP  and  to where they need to be  length wise
TIMS89CRAWLER [OP]
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #2 on: Nov 12, 2007, 10:51:34 AM »
do you know if the front mounts work? they look like they will be close but i need to measure to be sure.... i would rather notch the cab then run a body lift.... i am anti-body lift..... guess i will just have to see what happens thanks man
www.choptechfab.com
CHECK THE BUILD
« Reply #3 on: Nov 12, 2007, 10:54:48 AM »
i dont know  i would think they would be really close
NO  i dont like body lifts in general but sometimes   a  small one is needed
TIMS89CRAWLER [OP]
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #4 on: Nov 12, 2007, 11:52:32 AM »
yes this is true for sure i will see if i need one....
www.choptechfab.com
CHECK THE BUILD
Last post Jan 02, 2004, 12:01:38 PM
by 84runner
Last post Jan 12, 2007, 03:03:34 PM
by rlwjaw
Last post Jan 24, 2007, 05:13:36 PM
by blackdiamond
Last post May 31, 2007, 05:34:12 PM
by jimbo74
Last post Sep 27, 2007, 10:04:42 AM
by Slowzuk
