Author Topic: just makin sure..  (Read 1377 times)
GrenadedToy
  • Turtle Points: 49
  • Member since Jun '05
  • Maatt Daeemon
just makin sure..
« on: Jun 21, 2007, 07:30:10 PM »
can i use a transfer case e-brake kit if i run duals? i figured it might not cause the adapter moves your rear case 6" back, away from your stock ebrake set up in front of the gas tank..? anybody run this set up?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: just makin sure..
« Reply #1 on: Jun 21, 2007, 07:52:06 PM »
i am  99%  sure  that you CAN
if  using the Allpro,  and  you should be,   just   talk with Infernal,
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #2 on: Jun 21, 2007, 08:05:10 PM »
Im with coyotefrg. I think the only thing you have to do is change the length of the cable
Quote
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
« Reply #3 on: Jun 21, 2007, 08:23:56 PM »
Yes, it can be used but if you have a 4Runner with rear heat, you will have to relocate the heater hoses.  Also, you will have to bend the fuel lines out of the way.
GrenadedToy [OP]
  • Turtle Points: 49
  • Maatt Daeemon
« Reply #4 on: Jun 21, 2007, 11:42:10 PM »
  is sky's kit not any good?
Last post Feb 12, 2007, 09:27:19 PM
by FATB0Y
Last post May 15, 2007, 10:58:45 PM
by 82rustbeast
Last post Apr 17, 2013, 07:13:06 PM
by kneedownnate
