Author Topic: R151F Swap?  (Read 1392 times)
Yota Tony
  • Male Posts: 274
  • Member since Feb '07
R151F Swap?
« on: Apr 12, 2007, 06:16:25 PM »
I wondering if I can swap an R151F into my truck?
I know that Toyota uses 2 different bell housing bolt patterns for their transmissions. A small 9 bolt pattern and a large 9 bolt pattern. The R151F uses the large bolt pattern.
Now I'm going to assume that my 82 uses the small bolt pattern. So if I swap bell housings will I be able to bolt the R151F up to my 82?
Also will my 82 t-case bolt up to the R151F?
Anthony
Looking For 82-83 Hilux - Must Be 5spd, able to run and drive, Square headlights and no rust!
82 Build - http://board.marlincrawler.com/index.php?topic=31283 - Dead
inmyownsummerami
  • Male Posts: 243
  • Member since Oct '05
  • Rockin the White Wheels
Re: R151F Swap?
« Reply #1 on: Apr 12, 2007, 06:30:41 PM »
The R151 will bolt up to a 20r, 22r, 22re, 22ret(Turbo which it came with). The large/small pattern you are refering to is bell-housing to trans.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
 :greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: R151F Swap?
« Reply #2 on: Apr 12, 2007, 06:36:00 PM »
thats what i was thinking....
i was thinking why does it matter what thbellhousign the tranny bolts to, you should be worried about what bell with tranny mates to the engine....
Yota Tony [OP]
  • Male Posts: 274
Re: R151F Swap?
« Reply #3 on: Apr 12, 2007, 07:16:49 PM »
My question was really in regards to to the bell housing bolting to my 82.
Thanks for the answer.
Anthony
RRMike
  • Turtle Points: 2
  • Member since Dec '05
Re: R151F Swap?
« Reply #4 on: Apr 13, 2007, 07:39:08 PM »
And no your t-case won't work unless you have a 23 spline input in the (front) case.  Turbo trucks have 23 spline output and 23 spline cases.
Last post Dec 16, 2006, 11:15:01 AM
by toymech
Last post Jun 01, 2007, 06:54:58 PM
by Mark m.
Last post Mar 08, 2011, 09:18:31 AM
by 85yotapolo
Last post Dec 03, 2009, 10:37:08 PM
by zidaro
Last post Dec 02, 2009, 09:17:09 PM
by seafarinman
